unlimited package max 2.6mb speed
- unlimited package max 2.6mb speed
04-09-2009 8:52 AM
Ive found this to be the cap at anytime, if it is why do you advertise line speed for the off peak periods?.
Message 1 of 8
(1,291 Views)
7 REPLIES 7
Re: unlimited package max 2.6mb speed
04-09-2009 8:57 AM
Hi Babble,
Looking at your line, everything seems to be fine so I'm not sure why you're seeing those speeds.
What do you get from http://mybroadbandspeed.co.uk ?
Message 2 of 8
(632 Views)
04-09-2009 9:12 AM
My line is fine yes, just since i swapped from pro too the unlimeted package max speed at any time is 2.6 from anywhere whatever the time of day.
Message 3 of 8
(632 Views)
04-09-2009 9:23 AM
Prove it
Absolutely believe what you're saying, but it's extremely unlikely that that sort of thing would happen, especially given that the profile on your line is *completely* different.
Mind showing me the results of a test from that link above?
Message 4 of 8
(632 Views)
04-09-2009 11:01 AM
What type of traffic are you measuring at that speed? Some types of traffic are restricted, such as p2p and usenet.
Message 5 of 8
(632 Views)
04-09-2009 1:00 PM
Quote from: babble just since i swapped from pro too the unlimited package ...
How are you comparing this? On Pro, what speed did you get?
3Mb FTTC
3Mb FTTC
Message 6 of 8
(632 Views)
16-09-2009 11:07 AM
Sorry i meant to get back to this but i got a littlebusy )
http://www.thinkbroadband.com/speedtest/results/id/125309544927047223649.html
Speed Down 2665.31 Kbps ( 2.6 Mbps )
Speed Up 373.98 Kbps ( 0.4 Mbps )
i always got a solid 5.6 from there before i changed.
Now i am getting tons of timeouts on web pages and all i can put it down too is this package as all was fine before.
Message 7 of 8
(632 Views)
16-09-2009 11:29 AM
Ok - This is odd as the package you are on should be seeing speedtests come under 'web' traffic which is still prioritised.
What do you get when running a BT Speedtest from http://www.speedtester.bt.com ?
Message 8 of 8
(632 Views)
