sync decrease after some months on trial
- Re: sync decrease after some months on trial
28-06-2009 8:22 PM
After being on the trial now for several months (easter-ish) and having a sync around 11Mbps I have recently (in the last couple of weeks) seen it drop to 7Mbps. After the initial few weaks of training the 11Mbps was quite stable and similarly the 7Mbps appears also to be quite stable. I didn't notice any form of gradual decrease, just one day 11 next 7. I have an uncapped upload speed of almost 1.2Mbps which has been pretty stable since it was uncapped a few weeks after I moved onto the trial. SNR look similar although I didn't note them at the time (oopps). Current stats;
Downstream Upstream
Connection Speed 7101 kbps 1141 kbps
Line Attenuation 24 db 7 db
Noise Margin 16 db 4 db
My question is simple, where have my 4Mbps gone and, more importantly, how do I get them back?
-tony
28-06-2009 9:00 PM
The downstream SNR (noise) margin seems very high. If the target SNR margin really is that high that is the cause of your low sync speed.
David
01-07-2009 8:17 AM
Yes all the stats are stable after restarts and even and overnight powerdown. Now you mention it the downstrem noise margin used to be much better than that. I'm pretty confident that things are good at my end - I have the router plugged into a fairly new NT5E replacement adsl plate which hasn't changed - so any change would have to be on the line. Can I get BT to run a test or up the gain and is this likely to help?
-tony
01-07-2009 11:31 AM
I to have been on the trial since early May, I to have seen my sync speeds drop from 10meg with s/n of 6db,
(Att 40.5db)
The Dslam then daily (about 8ish) would drop sync and try various target s/n ratios,down to 3db, when 3db failed
as it would ,it put me up to 12db, then 9db, been 9db for weeks now,
What it won't seem to do, is go back to 6db where it is always had been,and was fine at 6db all day and all night long
So all in all I am about half a meg faster down,but at 6db it would sync in the high 8 megs
Trouble is because it insists on near daily re-syncs, My profile never catches up!
Synced at 7607 ATM but profile is 5.5meg and has been for weeks I believe
Later
01-07-2009 6:06 PM
-tony
06-07-2009 2:24 AM
07-07-2009 11:30 AM
Following the amount of 'Ticket Tennis' played at the start of the trial I have seriousley lost all interest in Broadband, I used to catch up with a few programs on BBC iPlayer but my pleasure has now been adulterated by a constant stuttering connection, and the tennis isn't on so that cant be blamed. The only up side is my upstream speed as trebled.
My present contract with Plusnet is finishing within the next three month, So I think I will be either going LLU or cable, I dont blame Plusnet fully, I have been with them for nearly five years so they cant be all bad. The problem as far as I can see is BT's archaic copper wire system.
John B.
07-07-2009 11:34 AM
Are you talking about the general broadband speeds or are we talking about sync speeds? If it's sync speeds then thats just from your router to the exchange and not dependant on any other ongoing activities (like the cricket/tennis/randomthingsgoingonintheworld).
Sounds initially like a change in the DLM, which seems to be somewhat volatile on ADSL2+.
07-07-2009 12:01 PM
Quote from: Jameseh Sounds initially like a change in the DLM, which seems to be somewhat volatile on ADSL2+.
I think you have hit the nail on the head James. I was talking about my variable sync speeds, it is just annoying that my once stable connection is now so erratic.
John B.
07-07-2009 12:03 PM
The DLM should recalculate after about 3 days.
07-07-2009 12:30 PM
Quote from: Jameseh John - How recently did the downturn in speed happen?
My Download speeds dived on June 25th and are still dropping my actual Sybnc speed is just begining to level off around the 5MB area. My downstream boise is anywhere between 16 and 12db it used to be between 4.5 and 8db prior to the trial it was a rock steady 6db 24/7 without a drop out or any other problem.
John B.
07-07-2009 12:55 PM
I take it you're wiring into the master socket with all of your telephone devices filtered and all the usual?
Is the any detectable noise on the telephone line itself?
07-07-2009 1:20 PM
With the length of my line and the attenuation the current values is where I think I should be. So be interesting if the DLM will maintain them.
07-07-2009 1:29 PM
Since June 25th thing are getting worse. Most of the time I am using my O2 wireless connection just to guarantee a steady speed. My usual monthly usage was in excess of 40GB+ this month due to the drop my usage is unlikely to even reach 16GB.
John B.
07-07-2009 8:51 PM
Upstream sync speeds tend to be 447kbps and 855kbps on alternate days! (I switch my router off each night)
The erratic nature of ADSL2+ is its Achilles heel.
