request dlm reset
- request dlm reset
- « Previous
- 1
- 2
- Next »
Re: request dlm reset
03-09-2017 8:55 AM
Thankyou very much for your help. Back to normal. I will monitor and when noise on line I will contact plusnet to fix, seems very intermittent. But dlm does not seem to automatically recover speed after noise has gone away.
03-09-2017 3:37 PM
Things do not quite work like that! The DLM will seek to maintain a stable connection, if that means raising the TARTGET SNRM (lowering the speed) then it gets adjusted until the connection remains stable. Whilst the connection remains not-disconnected, the speed will certainly remain unchanged. If there has been a disconnection for some reason there is some possibility that the DLM might improve the TARGET SNRM, but there is no assurance that will happen without a line reset.
If there is repeated need for a line reset, then that is indicative of a fault on the line or with consumer side wiring or equipment.
- « Previous
- 1
- 2
- Next »
