ps3 ping issue
- ps3 ping issue
ps3 ping issue
20-07-2009 9:28 PM
Other multi player games work well with no lag at all. As did GT5p a few months ago.
I have between a 3.5 and 4 meg connection with very low errors and interleave turned off .
If i do a tracert to bbc.co.uk over 30 hops the average is between 12-20ms but more recently the hops to the PN gateway have been over 250ms several times
Could someone please help as races get a big dull when its 1- on- 1 every time.
Thanks.
Re: ps3 ping issue
21-07-2009 10:50 AM
which product are you on and are u suree u havent gone over the usage allowence and having your speeds restricted
Re: ps3 ping issue
21-07-2009 8:56 PM
VP capacity is showing green,
I am on the Pro package for gamers and am nowhere near the 15gig limit .
Most of yesterday evening i had 4 or less cars on the grid out or 12 . So i tried a different PN gateway but it was no better.
Tracing route to bbc.co.uk [212.58.224.138]
over a maximum of 30 hops:
1 1 ms <1 ms 1 ms 192.168.1.1
2 25 ms 24 ms 16 ms lo0-plusnet.pcl-ag01.plus.net [195.166.128.27]
3 54 ms 73 ms 58 ms gi1-2-803.pcl-gw1.plus.net [84.92.5.57]
4 25 ms 14 ms 40 ms te2-1.pcl-gw02.plus.net [212.159.1.114]
5 121 ms 235 ms 227 ms te2-2.thn-gw2.plus.net [212.159.0.190]
6 20 ms 49 ms 31 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 67 ms 13 ms 30 ms 212.58.238.133
8 23 ms 24 ms 28 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
I am only assuming that this is the problem?
Re: ps3 ping issue
23-07-2009 8:17 PM
1 <1 ms <1 ms <1 ms 192.168.1.1
2 15 ms 18 ms 23 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 106 ms 41 ms 138 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 27 ms 12 ms 13 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 15 ms 13 ms 13 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 18 ms 16 ms 18 ms 212.58.238.14
7 13 ms 13 ms 13 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
1 1 ms <1 ms <1 ms 192.168.1.1
2 14 ms 15 ms 16 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 180 ms 159 ms 21 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 14 ms 13 ms 13 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 13 ms 15 ms 13 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 12 ms 13 ms 13 ms 212.58.238.149
7 14 ms 13 ms 13 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
2 26 ms 25 ms 18 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 15 ms 12 ms 13 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 65 ms 58 ms 222 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 57 ms 13 ms 13 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 14 ms 14 ms 15 ms 212.58.238.149
2 14 ms 15 ms 43 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 * * * Request timed out.
4 216 ms 13 ms 14 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 102 ms 13 ms 14 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 15 ms 13 ms 13 ms 212.58.238.149
7 20 ms 19 ms 15 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Could someone from from PN please help with this, as this is not typical of my connection
Re: ps3 ping issue
24-07-2009 9:50 AM
Re: ps3 ping issue
24-07-2009 2:36 PM
Normally i get about 500 ES and 900 CRC errors in 24hours according to routerstats .
Taken from router.
Type: Fast
Line Coding: Trellis On
Status: No Defect
Downstream Upstream
Rate (Kbps): 4224 448
SNR Margin (dB): 15.2 25.0
Attenuation (dB): 46.0 26.0
Output Power (dBm): 11.9 19.8
Super Frames: 28961329 28961327
Super Frame Errors: 4566 0
RS Words: 0 0
RS Correctable Errors: 0 1
RS Uncorrectable Errors: 0 N/A
HEC Errors: 2205 0
OCD Errors: 6 1
LCD Errors: 0 2
Total Cells: 609873140 0
Data Cells: 20151452 0
Bit Errors: 0 0
Total ES: 3961 0
Total SES: 90 0
Total UAS: 42 0
Re: ps3 ping issue
24-07-2009 4:26 PM
i dont get any problems from theses amounts of errors
Re: ps3 ping issue
25-07-2009 4:29 PM
Up time 91 hours
adsl: ADSL driver and PHY status
Status: Showtime Channel: FAST, Upstream rate = 448 Kbps, Downstream rate = 4224 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Fast
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 15.1 25.0
Attn(dB): 46.0 26.0
Pwr(dBm): 19.8 11.9
Max(Kbps): 4256 1116
G.dmt framing
K: 133(0) 15
R: 0 0
S: 1 1
😧 1 1
ADSL2 framing
MSGc: 1 1
B: 150 15
M: 1 1
T: 1 1
R: 0 0
S: 1.0000 1.0000
L: 1208 128
😧 1 1
Counters
SF: 34425673 34425671
SFErr: 6168 0
RS: 0 0
RSCorr: 0 1
RSUnCorr: 0 0
HEC: 3043 0
OCD: 7 1
LCD: 0 2
Total Cells: 1535303879 0
Data Cells: 24380559 0
Drop Cells: 0
Bit Errors: 0 0
ES: 5039 0
SES: 90 0
UAS: 42 0
Total time = 1 days 44 min 4 sec
SF = 35727920
CRC = 11902
LOS = 1
LOF = 9
ES = 5039
Latest 1 day time = 44 min 4 sec
SF = 155524
CRC = 65
LOS = 0
LOF = 0
ES = 24
Latest 15 minutes time = 14 min 4 sec
SF = 49619
CRC = 8
LOS = 0
LOF = 0
ES = 7
Previous 15 minutes time = 15 min 0 sec
SF = 52982
CRC = 32
LOS = 0
LOF = 0
ES = 11
Previous 1 day time = 24 hours 0 sec
SF = 5082319
CRC = 1137
LOS = 0
LOF = 0
ES = 884
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 52923
CRC = 25
LOS = 0
LOF = 0
ES = 6
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 52923
CRC = 4
LOS = 0
LOF = 0
ES = 4
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 52982
CRC = 7
LOS = 0
LOF = 0
ES = 6
AM still seeing bad times from PN . What could cause this?
2 14 ms 23 ms 12 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 170 ms 211 ms 214 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 76 ms 13 ms 14 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 13 ms 13 ms 12 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 46 ms 13 ms 12 ms 212.58.238.149
7 12 ms 13 ms 13 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Re: ps3 ping issue
25-07-2009 8:53 PM
i cant jump on the same gateway as you to test it out because am on the trial and locked to thn-ag2
Re: ps3 ping issue
27-07-2009 10:27 AM
It sounds like ASBO's suggestion would be well worth a try, you can find out what gateway you're on by visiting http://usertools.plus.net/@gateway - try dropping the connection and reconnecting after a couple of minutes (to make sure the exchange doesn't pick the disconnections up as a fault) then checking on the previous link to make sure you're on a different gateway to pte-gw2. See if that makes any difference to the ping times - it should do.
Hope that helps,
Re: ps3 ping issue
27-07-2009 11:10 AM
1 1 ms 1 ms 1 ms 192.168.1.1
2 20 ms 34 ms 38 ms lo0-plusnet.pcl-ag04.plus.net [195.166.128.134]
3 19 ms 24 ms 18 ms gi1-6-604.pcl-gw02.plus.net [84.92.0.229]
4 205 ms 195 ms 206 ms te2-2.thn-gw2.plus.net [212.159.0.190]
5 30 ms 16 ms 204 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 19 ms 14 ms 18 ms 212.58.238.149
7 16 ms 22 ms 19 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
I will another one
Re: ps3 ping issue
27-07-2009 12:09 PM
Re: ps3 ping issue
27-07-2009 1:09 PM
you wouldnt happen to be tvc colwal from tvcatchup.com would you. i ask as your using the same avatar http://forums.tvcatchup.com/showthread.php?t=3605
Re: ps3 ping issue
27-07-2009 4:58 PM
2 16 ms 19 ms 14 ms lo0.plusnet.thn-ag1.plus.net [195.166.128.101]
3 178 ms 225 ms 224 ms vl703.thn-gw2.plus.net [84.92.4.242]
4 14 ms 16 ms 14 ms rt0.thdo.bbc.co.uk [212.58.239.25]
5 13 ms 15 ms 15 ms 212.58.238.133
6 14 ms 16 ms 14 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
1 1 ms 2 ms 1 ms 192.168.1.1
2 16 ms 19 ms 16 ms lo0.plusnet.thn-ag1.plus.net [195.166.128.101]
3 15 ms 13 ms 14 ms vl703.thn-gw2.plus.net [84.92.4.242]
4 15 ms 15 ms 14 ms rt0.thdo.bbc.co.uk [212.58.239.25]
5 29 ms 14 ms 15 ms 212.58.238.149
6 14 ms 15 ms 15 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Interesting about the zero config issue but the problem is effecting the PS3 with the laptop turned off plus i use the laptop on other routers.
(sorry to disappoint but i'm not tvc colwal
Re: ps3 ping issue
27-07-2009 7:38 PM
Quote Interesting about the zero config issue but the problem is effecting the PS3 with the laptop turned off plus i use the laptop on other routers.
i wasnt saying that disabling WZC would cure the ps3 problem just that when testing pings on a pc over wireless its best to disable this service to allow true accrute test results
