plusnet Email sent form mobile phone Help
- plusnet Email sent form mobile phone Help
27-05-2009 6:24 PM
im trying to use it exactly as its set up on my p.c
that is:
User name : plusnet log in
password: same as my plusnet log in
smtp server : relay.plus.net ( exactly as itsays it should be on the conection details part of the main plusnet website )
port: 25
this is using Three as the mobile network.
How can i get this to work?
Re: plusnet Email sent form mobile phone Help
27-05-2009 6:37 PM
Or
Change to use 3's SMTP Server for sending mails.
PN's (as most) only allows you to send without authenticating yourself when you are attached to their network, hence 3's should let you without authentication, or PNs will with authentication.
27-05-2009 6:41 PM
27-05-2009 6:49 PM
Mike
adie:quote
27-05-2009 6:54 PM
smtp.three.co.uk
As your outgoing mail relay =.
27-05-2009 7:04 PM
Quote Do 3 allow access to other peoples SMTP servers when connected to their network?
I'm pretty sure I've used the PlusNet authenticated SMTP on my daughters laptop, connected to 3 with a mobile broadband dongle.
Could be a while ago though!!
27-05-2009 7:20 PM
Quote from: James_G smtp.three.co.uk
I'd love to but it seems not to be designed for non-3 email accounts as it adds (or replaces) a reply-to: in the form of <name>@3mail.com which is about as much use as a chocolate teapot. Unless of course I've bu**ered up the settings on this 'ere E71. When I've got a spare tuit I'll try telneting to smtp.three.co.uk:25 and manually enter the smtp dialogue just to see where the reply-to: is/isn't being set up.
Mike
27-05-2009 7:25 PM
Assuming that they are correct in their assertion that their product works, its hopefully just a case of locating the correct settings - I tried in vain to locate a setup guide on their site though.
They do block port 25 though, again according to their help pages. So you have to use their SMTP server for outgoing mails.
27-05-2009 7:30 PM
27-05-2009 7:35 PM
All SMTP Servers do is relay messages onto the receiver based upon the address of the recipient.
Since having an open relay would be bad in terms of SPAM (and effectively paying and resourcing a tool for non-customers), but requiring everyone to use a password and username to access their SMTP Server would require a lot of processing overhead, most ISPs simply provide an open relay for all users connected to their network.
But all they really do is look at the domain part of the address, and send it to the IP address identified by the MX record for the domain in question (or the A record if no MX record exists)
27-05-2009 8:36 PM
Quote from: pint If i used Threes smtp server, would the e-mail sent still be from emailaddress@plus.com ?
Just tried iot on threes smtp server, to my hotmail account, and it was listed as being from my 3 mobile account, and not from the plusnet account.
how can i make it so its from mailboxname@plus.com ? and not phonenumer@3mail.com
27-05-2009 8:50 PM
Mike
27-05-2009 9:23 PM
PN email works perfectly on my iPhone via the O2 network (although you do need to add your PN username/mailbox name and password to your SMTP settings).
It must be a network thing.
27-05-2009 10:26 PM
OK, just found the following info on t'web which someone winkled out of 3 support.
Change the smtp server to smtp-mbb.three.co.uk as this one doesn't rewrite addresses on the fly in the same way that smtp.three.co.uk does. I assume that smtp.three.co.uk is solely for 3's own email service and that smtp-mbb.three.co.uk is for evryone else (mbb == mobile broadband?). Note: normally email sent through smtp.three.co.uk doesn't get counted against your data allowance; I'm not sure if this is true for smtp-mbb.three.co.uk so you might want to experiment before sending large attachments.
I can now send email from a 3 mobile with the from and reply-to headers set to whatever I want - yippee!
Mike
28-05-2009 11:16 AM
I had a VERY fun conversation with Three MBB support about this for a friends father
