please help am i being Dossed muliple router disconnects
chris300
Would some kind soul please help me, ive had my router disconnecting all day checked my logs and notice Dos attack is there anyway i can prevent this.
[Internet connected] IP address: 146.90.244.93, Friday, Nov 16,2018 16:31:34
[DSL Event] DSL: Up Friday, Nov 16,2018 16:31:28
[Admin login] from source 192.168.0.4, Friday, Nov 16,2018 16:30:42
[DSL Event] DSL: Down Friday, Nov 16,2018 16:30:07
[DOS Attack] : 2 [ACK Scan] packets detected in last 20 seconds, source IP [88.221.16.253]
Friday, Nov 16,2018 16:29:00
[DOS Attack] : 1 [ACK Scan] packets detected in last 20 seconds, source IP [2.19.61.46]
[UPnP set event: Public_UPNP_C3] from source 192.168.0.4, Friday, Nov 16,2018 16:27:59
[DOS Attack] : 1 [ACK Scan] packets detected in last 20 seconds, source IP [23.64.27.236]
Friday, Nov 16,2018 16:27:37
[DOS Attack] : 1 [ACK Scan] packets detected in last 20 seconds, source IP [88.221.16.253]
Friday, Nov 16,2018 16:27:35
[UPnP set event: Public_UPNP_C3] from source 192.168.0.4, Friday, Nov 16,2018 16:25:06
[DHCP IP: (192.168.0.4)] to MAC address F8:46:1C:41:73:CB, Friday, Nov 16,2018 16:25:03
[Time synchronized with NTP server] Friday, Nov 16,2018 16:25:02
[Internet connected] IP address: 146.90.244.93, Friday, Nov 16,2018 16:25:02
[DSL Event] DSL: Up Friday, Nov 16,2018 16:24:56
[UPnP set event: Public_UPNP_C3] from source 192.168.0.4, Friday, Nov 16,2018 16:24:17
[UPnP set event: Public_UPNP_C3] from source 192.168.0.4, Friday, Nov 16,2018 16:23:59
[DHCP IP: (192.168.0.4)] to MAC address F8:46:1C:41:73:CB, Friday, Nov 16,2018 16:23:57
[Initialized, firmware version: V1.0.0.102_1.0.102] Friday, Nov 16,2018 16:23:38
7 REPLIES 7
EmilyD
Fixes: 117
Re: please help am i being Dossed muliple router disconnects
Hi @chris300,
I'm sorry that you're experiencing drops in connection and for any inconvenience that this is causing you. The logs above don't necessarily indicate that you're experiencing a DOS attack as it could be the router creating a false positive when the connection drops, but I'd recommend changing your router's password if you have any concerns.
Having tested your line today it appears the dropping connection issue may be due to a setting being incorrect.
The signal to noise ratio (SNR) is too low for the length of your line. The SNR helps the line to remain stable and unaffected by noise or interference on the line. The higher the setting for SNR, the higher the level of noise can be tolerated.
The SNR for your line was set too low for the amount of interference we'd expect to see, so by increasing this we expect the connection to now stabilise and for the information to be received without interference.
Please keep an eye on your connection over the next few days. If the connection issue persists, please run through our troubleshooting guides here and let us know how you get on.
 Emily D
chris300
hello EmilyD
Thanks for replying and apologies for my late reply, im still having issues constant dropout on online gaming to the point id given up with it, now i can barely listen to DAB radio without disconnects
changed password and router username, here is a router log from this morning
[DOS Attack] : 1 [ACK Scan] packets detected in last 20 seconds, source IP [2.17.145.7]
Saturday, Dec 08,2018 13:19:20
[Time synchronized with NTP server] Saturday, Dec 08,2018 13:17:50
[Internet connected] IP address: 31.185.249.126, Saturday, Dec 08,2018 13:17:39
[DSL Event] DSL: Up Saturday, Dec 08,2018 13:17:34
[Admin login] from source 192.168.0.4, Saturday, Dec 08,2018 13:16:43
[DSL Event] DSL: Down Saturday, Dec 08,2018 13:16:13
[Time synchronized with NTP server] Saturday, Dec 08,2018 12:47:14
[Internet connected] IP address: , Saturday, Dec 08,2018 12:46:29
[DSL Event] DSL: Up Saturday, Dec 08,2018 12:46:21
[DSL Event] DSL: Down Saturday, Dec 08,2018 12:45:02
[UPnP set event: Public_UPNP_C3] from source 192.168.0.4, Saturday, Dec 08,2018 12:43:56
[DOS Attack] : 1 [ACK Scan] packets detected in last 20 seconds, source IP [88.221.41.8]
Saturday, Dec 08,2018 12:26:49
[Time synchronized with NTP server] Saturday, Dec 08,2018 12:26:37
[Internet connected] IP address: 31.185.249.126, Saturday, Dec 08,2018 12:26:36
[DSL Event] DSL: Up Saturday, Dec 08,2018 12:26:30
[DHCP IP: (192.168.0.2)] to MAC address 00:26:B0:1C:14:3B, Saturday, Dec 08,2018 12:26:04
[DHCP IP: (192.168.0.4)] to MAC address F8:46:1C:41:73:CB, Saturday, Dec 08,2018 12:26:00
[Initialized, firmware version: V1.0.0.102_1.0.102] Saturday, Dec 08,2018 12:25:41
Thankyou, i will keep a constant look out at this website today to see if ive had a reply
so as not to leave it to late to reply back Thanks again for the explanation.
chris300
to show how frequent this problem is here is another log posted 20 mins from my previous log showing another disconnect as you can see this is happening frequently 4,5 times an hour
Admin login] from source 192.168.0.4, Saturday, Dec 08,2018 13:51:14
[Time synchronized with NTP server] Saturday, Dec 08,2018 13:45:09
[Internet connected] IP address: 31.185.249.126, Saturday, Dec 08,2018 13:44:59
[DSL Event] DSL: Up Saturday, Dec 08,2018 13:44:51
[DSL Event] DSL: Down Saturday, Dec 08,2018 13:43:30
[Admin login] from source 192.168.0.4, Saturday, Dec 08,2018 13:34:17
[Admin login] from source 192.168.0.4, Saturday, Dec 08,2018 13:27:38
 Thankyou
chris300
Time synchronized with NTP server] Saturday, Dec 08,2018 23:48:58
[DHCP IP: (192.168.0.2)] to MAC address 00:26:B0:1C:14:3B, Saturday, Dec 08,2018 23:48:17
[Internet connected] IP address: 80.189.197.204, Saturday, Dec 08,2018 23:47:43
[DSL Event] DSL: Up Saturday, Dec 08,2018 23:47:37
[DSL Event] DSL: Down Saturday, Dec 08,2018 23:46:45
[DOS Attack] : 1 [ACK Scan] packets detected in last 20 seconds, source IP [23.198.74.134]
Saturday, Dec 08,2018 23:45:31
[Admin login] from source 192.168.0.4, Saturday, Dec 08,2018 23:43:25
[Time synchronized with NTP server] Saturday, Dec 08,2018 23:39:55
[Internet connected] IP address: , Saturday, Dec 08,2018 23:39:45
[DHCP IP: (192.168.0.2)] to MAC address 00:26:B0:1C:14:3B, Saturday, Dec 08,2018 23:39:44
[DSL Event] DSL: Up Saturday, Dec 08,2018 23:39:40
[DSL Event] DSL: Down Saturday, Dec 08,2018 23:38:21
[Time synchronized with NTP server] Saturday, Dec 08,2018 23:31:06
[DHCP IP: (192.168.0.2)] to MAC address 00:26:B0:1C:14:3B, Saturday, Dec 08,2018 23:30:59
[Internet connected] IP address:, Saturday, Dec 08,2018 23:30:55
[DSL Event] DSL: Up Saturday, Dec 08,2018 23:30:50
[DSL Event] DSL: Down Saturday, Dec 08,2018 23:29:31
SammyM
Fixes: 96
Hello @chris300,
Thanks for getting in touch and we are sorry to see that you are experiencing issues with your connection. It certainly is dropping more than we would like, however our tests are not picking up anything external causing the issue.
Please can you plug in your equipment into the test socket by following the guide here. Once in test socket please monitor over 24 hours and if the drops continue, please raise a fault here.
 Sammy M - Sheffield Team
chris300
Hello SammyM
heres a log from this morning, still getting disconnected. will plug into test socket
thankyou for replying
[Admin login] from source 192.168.0.4, Monday, Dec 10,2018 10:57:10
[UPnP set event: Public_UPNP_C3] from source 192.168.0.4, Monday, Dec 10,2018 10:43:26
[Time synchronized with NTP server] Monday, Dec 10,2018 10:42:25
[Internet connected] IP address: 91.125.106.28, Monday, Dec 10,2018 10:42:15
[DSL Event] DSL: Up Monday, Dec 10,2018 10:42:09
[DSL Event] DSL: Down Monday, Dec 10,2018 10:41:17
[UPnP set event: Public_UPNP_C3] from source 192.168.0.4, Monday, Dec 10,2018 10:38:53
[DHCP IP: (192.168.0.4)] to MAC address F8:46:1C:41:73:CB, Monday, Dec 10,2018 10:38:52
[Admin login] from source 192.168.0.4, Monday, Dec 10,2018 10:35:51
[DHCP IP: (192.168.0.2)] to MAC address 00:26:B0:1C:14:3B, Monday, Dec 10,2018 10:34:42
[Time synchronized with NTP server] Monday, Dec 10,2018 10:34:25
[Internet connected] IP address: 146.90.244.84, Monday, Dec 10,2018 10:34:15
[DSL Event] DSL: Up Monday, Dec 10,2018 10:34:09
[Initialized, firmware version: V1.0.0.102_1.0.102] Monday, Dec 10,2018 10:33:12
[DSL Event] DSL: Down Monday, Dec 10,2018 10:32:47
[Time synchronized with NTP server] Monday, Dec 10,2018 10:32:18
[Internet connected] IP address: 146.90.244.84, Monday, Dec 10,2018 10:32:18
[DSL Event] DSL: Up Monday, Dec 10,2018 10:32:11
[Admin login] from source 192.168.0.4, Monday, Dec 10,2018 10:32:10
[Initialized, firmware version: V1.0.0.102_1.0.102] Monday, Dec 10,2018 10:29:44
SammyM
Fixes: 96
Awe no problem @chris300. Please let me know how you get on.
