phone causes internet to disconect
- Re: phone causes internet to disconect
10-01-2020 9:07 AM
phone call causes internet to dis connect,,,
done it for years since before joining you
fed up with it
think its a dodgy connection
Message 1 of 2
(388 Views)
1 REPLY 1
10-01-2020 5:40 PM
Hi there, I've just tested your line and the results are showing something called a "loop fault" as that can be caused by equipment or wiring plugged into the line it would be best if I can test your line again with everything unplugged from it. That way if the same result shows on our tests it will confirm that it's an Openreach fault with the line.
Please let me know if we can get that arranged with you.
Message 2 of 2
(344 Views)
