pcl-ag08 with dire speeds atm
- Re: pcl-ag08 with dire speeds atm
01-02-2012 9:44 PM
Yet to try a gateway hop but all speed tests give the same result.
One spanner that might be in the works, I had my usage warning email tonight and my speed dropped soon after, so maybe the restrictions script kicking in too early
Is my current usage via the portal.
edit: pcl-ag06 the same
Quote Download speedachieved during the test was - 357 Kbps
For your connection, the acceptable range of speeds is 1200-4000 Kbps.
Additional Information:
Your DSL Connection Rate :3072 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
IP Profile for your line is - 2709 Kbps
Quote This month you've used 48.18GB of your 60GB allowance
FTTP 500 regrade from Tues 28th November
Message 1 of 9
(1,576 Views)
8 REPLIES 8
01-02-2012 9:55 PM
Message 2 of 9
(812 Views)
02-02-2012 8:14 AM
Message 3 of 9
(812 Views)
02-02-2012 8:31 AM
It's the same on pcl-ag05, I can't even get the "My Broadband Speed" speed test to run.
Bob
Bob
Message 4 of 9
(812 Views)
02-02-2012 8:38 AM
Looks like last nights Traffic Management work, didn't. 2 warm reboots after 8am and still on the default profile
edit: yep http://www.plus.net/supportpages.html?a=2 it went wrong, time to change the default profile from its current treacle setting
Message 5 of 9
(812 Views)
02-02-2012 8:43 AM
I believe work is over running 10am is the latest estimate from tech support.
Message 6 of 9
(812 Views)
02-02-2012 8:45 AM
Taken about 4 re conects post 8am to get back to my 5mb speed from 0.3! Thanks Plusnet was unable to watch a program on iplayer before work...
By the way good on thn-ag2
James
James
Message 7 of 9
(812 Views)
02-02-2012 8:49 AM
Hi, please see my post here: http://community.plus.net/forum/index.php/topic,102118.msg866967.html#msg866967
This explains the issues on the network at the moment.
Message 8 of 9
(812 Views)
02-02-2012 9:21 AM
mod:note
Locked in favour of other thread which contains the answer.
Message 9 of 9
(812 Views)
