p2p speed fluctuation
- p2p speed fluctuation
14-06-2015 3:40 PM
Hi guys, I'm trying to transfer files between computers and the speed is changing dramatically. As soon as I start the program the speed goes up to 1.8MB/s then drops after 30 seconds to ~300kb/s.
I've just double checked and all the ports I need are open and the strange thing is once I manually change ports within the program the speed shoots back up then drops again after about 30 seconds.
This wasn't a problem when I was with TalkTalk, does anyone else have this problem? Does Plusnet throttle?
Message 1 of 7
(1,029 Views)
6 REPLIES 6
Re: p2p speed fluctuation
18-06-2015 3:03 PM
bump
Message 2 of 7
(641 Views)
18-06-2015 3:14 PM
Quote from: y2kinder Hi guys, I'm trying to transfer files between computers and the speed is changing dramatically.
Is this between 2 computers on the same local connection, or over the internet?
Quote from: y2kinder As soon as I start the program the speed goes up to 1.8MB/s then drops after 30 seconds to ~300kb/s.
Upload speed or download speed?
Quote from: y2kinder Does Plusnet throttle?
No.
Message 3 of 7
(641 Views)
18-06-2015 3:22 PM
Transferring over the internet, downloads start at normal speed then drop after 30 seconds and only go back up when I change ports manually.
Message 4 of 7
(641 Views)
22-06-2015 10:39 AM
bump
Message 5 of 7
(641 Views)
22-06-2015 3:49 PM
P2P issues aren't simple to investigate really due to the nature of seeding, upload speeds that are part of this too. Are there a lot of seeds and what happens if you try using a well seeded file? What speeds are you seeing?
Message 6 of 7
(641 Views)
22-06-2015 3:58 PM
it could also be an issue at the remote end.
Message 7 of 7
(641 Views)
