my router stats
- my router stats
- « Previous
- 1
- 2
- Next »
Re: my router stats
16-07-2009 8:52 AM
Re: my router stats
16-07-2009 9:47 AM
I wouldn't switch off more than once a day as it is just possible that the automatic systems might think it is a bit unstable
Re: my router stats
16-07-2009 10:22 AM
Re: my router stats
16-07-2009 11:36 AM
if youve got the profiles the right way round in your last post and bts is now at 7150 an PN's at 2000 hopefuly the pn one will update at some point today
Re: my router stats
16-07-2009 1:22 PM
Re: my router stats
16-07-2009 2:54 PM
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 8096 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7000 kbps
Actual IP throughput achieved during the test was - 4594 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
And my router stats after reboot are..
Statistics Downstream Upstream
Line Rate 8096 Kbps 448 Kbps
Attainable Line Rate 10880 Kbps 1136 Kbps
Noise Margin 14.3 dB 25.0 dB
Line Attenuation 0.0 dB 5.5 dB
Output Power 12.4 dBm 15.8 dBm
Seems my pn profile has updated from 2000 to 7000..
Re: my router stats
16-07-2009 3:04 PM
Re: my router stats
16-07-2009 3:15 PM
Re: my router stats
16-07-2009 3:51 PM
Re: my router stats
16-07-2009 4:36 PM
Re: my router stats
16-07-2009 4:37 PM
Re: my router stats
16-07-2009 5:33 PM
you may as well wait for the 10 days to be up if your gaming is pretty fine at the mo then there is no risk of you lowering your fault theshold rate during the training
- « Previous
- 1
- 2
- Next »
