loss of power
- loss of power
loss of power
15-07-2009 10:05 AM
downstream rco is 91% (3657kbps) the routers done the math and gave me 3328 is it possible for plusnet to adjust the downstream rco to say 95% ?
this has been 99% in the past.
if that could be done i would be getting 3657 - 5% which would give me 3474 sync with the current line conditions
can anyone recommend something i can do to achieve the 3mb profile
thats for any advice !
Re: loss of power
15-07-2009 10:15 AM
You could also, at the same time, try resynching with no phones connected - it might give you a bit more speed
Of course the best thing is to have a router which enables you to fiddle with the noise margin
Re: loss of power
15-07-2009 10:28 AM
when the connection lost power at night the connection resynced with a snr of 9 and the router synced at 2560
by 9am today the snr margin was sitting at 11db which i thought was the perfect time to get my connection sync back
ive resynced and the target snr has went back to 9db and with a sync of 3328
im convinced my line attenuation now reading 59db instead of the orginal 55/56db is giving me less flexability on my line
i have the ST585 v6 flash_image=6.1.4.3.0 i can adjust snr if i were to want to
Re: loss of power
15-07-2009 10:36 AM
However your comment about the change in attenuation is disturbing - was this with the same router and firmware
Re: loss of power
15-07-2009 11:44 AM
since going back onto bts kit my attenuation has been reading 59db
this was all using adsl1 modulation with adsl 2 modulation my reported attenuation on talk talks kit was 54db although i prefered using adsl1 as i felt it gave a more consistant connection speed ive yet to try adsl2+ on my line.
i definitely notice my night time snr is worse than it ever was to my knowledge
Re: loss of power
15-07-2009 11:51 AM
i didnt actually realise it was running so badly i will reconnect in a moment to see what happens
Re: loss of power
15-07-2009 11:58 AM
Re: loss of power
15-07-2009 12:00 PM
Re: loss of power
15-07-2009 1:33 PM
i will give this a go though james just to experiment im trying not to tamper with things as i dont want this bras profiling system punishing my reconnects
i will report back shortly
Re: loss of power
15-07-2009 1:45 PM
Re: loss of power
15-07-2009 1:49 PM
My line at home has a forced SNR of 3dB and I can't remember it dropping at all.
Re: loss of power
15-07-2009 1:53 PM
Present stats
Noise Margin: 8.1 dB
Connection Rate: 3776 Kbps
Line Attenuation: 53.0 dB
Power: 18.8 dBm
Max Rate: 4096 Kbps
Re: loss of power
15-07-2009 2:37 PM
crazy amount of errors collected i knew before trying this it wasnt going to solve my issue the connection has dropped whilst i was at the shop
this line never has a phone connected to it and im running just a master socket with adsl nation filter plate
oldjim i never seem to get more than 18db power down the line i imagine a little more power and i would achieve better signal to noise margins
Re: loss of power
15-07-2009 2:40 PM
Re: loss of power
15-07-2009 2:58 PM
im trying what jamesh suggested
if you compared my two latest images they are from the same sync event on my connection. Why would the snr be dancing like that one minute then my lines scraping 0db and the next its got alot of signal to noise ration on some tones it never used to do that ive used router stats before and i used to get a almost straight line that would decrease at night. and my tones would be alot more equal generally.
