gateway changes
- gateway changes
- « Previous
- 1
- 2
- Next »
Re: gateway changes
08-09-2014 10:39 PM
sorted
got tg582 on now so they can run their tests
Message 16 of 19
(277 Views)
Re: gateway changes
09-09-2014 7:59 AM
They can run tests anyway, it's perhaps only the Modem that will have a direct effects on test results that may be run by BTw/Openreach, not the Router. Most of them won't give a stuff what Router you use - as long as it's not the source of PPP issues or blowing up the Modem! Generally, as far as which Router is used, it's down to the level of support that might be possible.
Message 17 of 19
(277 Views)
Re: gateway changes
09-09-2014 11:20 AM
done speed test with the plus net router connected
andjust the same speed
http://www.thinkbroadband.com/speedtest/button/141026143304563724529.png
Message 18 of 19
(277 Views)
Re: gateway changes
15-09-2014 2:31 PM
well as expected they said no faults on line and speed was performing within expectations of the 27 Mbps at the set up of service but i have no record of them saying that.
this was in email they sent before i was connected
Your Order
Broadband Product:
Plusnet Essentials Fibre
18 month contract
(40GB usage allowance**)
Estimated Broadband Speed:
40 Mbps
(Accurate to within +/- 1Mbit)
fttc went live on 04/06/13 and on the12/06/13 received email with this in it
plusnet have tested the line again today and I am happy to report the line is stable and the speed is good at around 37Mbps
Your Order
Broadband Product:
18 month contract
40 Mbps
Message 19 of 19
(277 Views)
- « Previous
- 1
- 2
- Next »
