could someone please check
- Re: could someone please check
05-04-2008 3:23 PM
Hi basically i have a pc running my broadband connection with a voyager 210.
I want to use a laptop in another room, are these my options.
(!) i hardwire the laptop to the router and use it that way
(2)go wireless,iassume the wireless router replaces the voyager210.
Is this correct or am i missing something(apart from a brain)
pc is running xp and laptop is running vista.
If wireless is the answer then netgear dg834g seems to be the router of choice,if that is so can you advise me where i might get one at areasonable price.
Thanks for all your help.
Message 1 of 3
(937 Views)
2 REPLIES 2
05-04-2008 3:38 PM
Sounds about right.
PC world (and others) have been doing good deals on various Netgear DG834 models often with a wireless USB adapter too for about £40 or less.
Message 2 of 3
(356 Views)
05-04-2008 3:53 PM
Remember that is buying from PC World, if you reserve online for instore collection, you get the web price.
Avoid the DG834PN, it has abad "not as good as the others" rep.
Message 3 of 3
(356 Views)
