change package
- change package
change package
15-09-2007 2:02 PM
Hi I want to Change my package, from BB+ onto Yourway 2 so i can do a bit of light P2P at reasonable speeds But can someone tell me
1. (apart from the monthly line rental) how much will it cost (if anything to move) i couldnt really find anything about this (maybe im been stoopid)
2. how long will it take?
Message 1 of 5
(1,281 Views)
4 REPLIES 4
Re: change package
15-09-2007 2:06 PM
1) nothing - it's free to change and the new account is the same price so there'll be no difference there either
2) Instantly, as soon as the request is raised (just click the 'upgrade' button in your members centre, at the top) and then post here to let us know that the ticket is raised. We can then action it for you.
Hope this helps,
Hope this helps,
Message 2 of 5
(463 Views)
Re: change package
15-09-2007 2:12 PM
Spot on!!!!!
Ive done it id 22854762
thanks very much!
thanks very much!
Message 3 of 5
(463 Views)
Re: change package
15-09-2007 2:18 PM
No worries, that's been actioned for you. All you need to do now is reconnect and you should be on the new account type.
Message 4 of 5
(463 Views)
Re: change package
15-09-2007 2:26 PM
Just got the confirmation mails now - and rebooted
Thanks again, thats fantastic service 🙂
Message 5 of 5
(463 Views)
