cant get iplayer on TV but Ok on PC
- Re: cant get iplayer on TV but Ok on PC
- « Previous
- 1
- 2
- Next »
05-02-2012 11:40 AM
Have you tried a different ethernet cable for the Humax as if the PC is able to get iPlayer it may not be the router that is faulty.....could be wrong though.
Or is it possible for you to try something else on the end of the cable to the Humax such as a laptop or your computer?
Message 16 of 23
(569 Views)
05-02-2012 11:53 AM
OK.
FIRST you need to apply the DHCP setting then wait. Ideally exit the menus, turn off the box for a minute or so then back on and leave it a few minutes more.
If you can turn off the router at the same time even better.
Then check in the Network settings and see if it has been allocated an IP address.
If it has it should work, if not further troubleshooting is required. This needs to be done SYSTEMATICALLY.
It could for example be the Humax box, the cable, the port on the router, the router core or something else.
Message 17 of 23
(569 Views)
05-02-2012 12:14 PM
good thinking will try my other ethernet cable and also going to try a playstation box...
Message 18 of 23
(569 Views)
05-02-2012 12:28 PM
Only change ONE THING AT A TIME.
And write down the results.
Message 19 of 23
(569 Views)
05-02-2012 12:36 PM
![Cheesy Cheesy](/html/@69488338D0B3891CC5F8AEAEEB30C648/images/emoticons/cheesy.gif)
FANTASTIC
Was the ethernet cable. One supplied by Humax was no good. My own tatty one worked immediately.
thank you everyone...very helpful
cindy
Message 20 of 23
(569 Views)
05-02-2012 12:43 PM
Quote from: suffolkcindy Was the ethernet cable.
And almost certainly DHCP.
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
Always tricky when there's 2 things wrong.
And infinitely more so when one "party" just blames the other.
![Angry Angry](/html/@8746C25E4D2FCE77DBF681B64ABA6B5A/images/emoticons/angry.gif)
Message 21 of 23
(569 Views)
05-02-2012 1:17 PM
Good to hear you are sorted Cindy
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Message 22 of 23
(569 Views)
05-02-2012 2:18 PM
There you are.
the Plusnet help desk gave you the good answer
![Cool Cool](/html/@852392E900DCC025F17256C42EA8F698/images/emoticons/cool.gif)
Message 23 of 23
(569 Views)
- « Previous
- 1
- 2
- Next »
