cannot find network
omg
cannot find network
:'(lease can anyone help.Have just signed up to plusnet and have received a thomson gateway router.Unfortunately when we try to configure our computer does not detect it on networks and therefore can't go any further.Using a friends laptop at the mo to post.I have tried wrelessly and with the ethernet cable but neither make any difference. Heres hoping that someone can help. Roll_eyes
22 REPLIES 22
Santiago
Re: cannot find network
Fixes: 1,485
Or call support and they might be able to talk you through some things over the phone.
omg
Thank you both but The set up guide doesn't help because I dont get the thomson window up even when type it in internet explorer.Have also spoken to support who told be that i needed to configure the router on another computer which I have done without any problem but it still won't work on my own PC.
Oldjim
Resting Legend
Fixes: 63
Is this the first time you have had broadband - the reason for asking is to find out if that computer could ever connect to a router via the network cable
Which operating system are you using
Santiago
What anti virus /firewall software are you using on the problem PC.
You may have to configure it to access the router.
omg
Hello again no I,ve had Aol broadband before and that seemed ok I'm on Windows Xp. I have noticed though when I go onto network connections where I use to have Network 2 that now seems to have disappeared .Would that have anything to do with it? I've also disconnected my firewall but still no luck.
Thank you for staying with me on this Wink
Fixes: 1,485
when you have tried with the ethernet cable do you get a flashing icon in your system tray near the clock that looks like a couple of computers?
omg
No not getting that either. Cry
Fixes: 1,485
If you to Start > Control Panel > Network Connections  do you have anything for Local Area Connection?
Is it disabled?
Santiago
Are you connecting to your router with your friends laptop?
omg
I do have a local area connection now number 6 and its not disabled.I think possibly its there because hubby managed to put it there.
Yes I am using the router on my friends laptop no problems.
Fixes: 1,485
What does local area connection #6 indicate when the ethernet cable is plugged in?
omg
Do you mean if it is connected? Yes it says that it is .
Fixes: 1,485
can you open a command prompt (start > run > cmd.exe)  and type ipconfig in it and copy the results back here?
