bad ping
superbin
bad ping
hi guys good to be here for past week I had internet problems they passed it to fault took a week to say no fault but can see some disconnections problems on my line my speed up and down also I getting high ping when I play online games ping is up and down any help cheers
12 REPLIES 12
Fixes: 1,600
Re: bad ping
Hi there.
I'm sorry to hear you're experiencing connection problems.
I'd recommend raising a fault to us at http://faults.plus.net letting us know when you've completed it and we'll pick it up.
superbin
Re: bad ping
hi there had openreach out this morning he said my line is fine did change microfilter but my ping still really high when playing online games can we try anything to lower my ping cheers
superbin
Re: bad ping
hi m8 still having problems cheers
EmilyD
Fixes: 117
Re: bad ping
Hi @superbin,
I'm sorry to hear that the engineer wasn't able to resolve this for you.  I've tested your line today and have found a potential issue with some of the underlying line settings. I've adjusted these now, please monitor your connection over the next 2-3 days and let us know if you're still experiencing any problems. I've added a bit more information on the fault ticket here.
 Emily D
superbin
Re: bad ping
hi again i was getting 6mb if im lucky now im only getting just over 3mb when i did test and ping seems little higher anything eles i could try as this speed is a nightmare cheers
superbin
Re: bad ping
hi again my ping seem worst can u put it back the way it was b4 or is there anything eles we could try thanks again
MatthewWheeler
Fixes: 479
Re: bad ping
Can you advise what ping times you're currently seeing?
It may also be worth carrying out a traceroute to the server in question.
 Matthew Wheeler
superbin
Re: bad ping
hi its up and down best ping is 300 but then rise to about 1120 with online gaming cheers
MatthewWheeler
Fixes: 479
Re: bad ping
Can you use a tool such as ping plotter and post the results?
We'll need more info to investigate this properly.
 Matthew Wheeler
superbin
Re: bad ping
hello since u put my line back up to max speed 22mb im getting 17mb also my ping seem to have inproved just did 5 min of online gaming was 148 ping shall i see how it goes for a day or two because seem better at moment cheers
superbin
Re: bad ping
hi again tested for 24h seem a lot better now my line on 22mb is there anyway i could try to up my line to get a faster speed worth a try if this is possible thanks
MatthewWheeler
Fixes: 479
Re: bad ping
Glad to hear you've seen a increase.
With regards to speeds your currently within the estimates for your line.
The only way to get faster speeds would be to upgrade to fibre but unfortunately this isn't available for you as you're connected directly to the exchange.
 Matthew Wheeler
