bad evening connection
- bad evening connection
03-01-2012 9:40 PM
ok i am a old gamer but this is why i have my PC, but last two night especially i have been unable to play due to a unacepable connection , its wierd as i play during the day with no problems but nite time is now impossible
i play BF3 now they have added a ingame icon " a orange warning showing a diconnected plug " meaning you are losing conection to server .
tonite i did a win7 repair , reinstalled the game , swapped the router for another i have from PN a thompson .
dissabled UPNP . wired to test socket direct to router , and still get the disconect !!!!
i am wondering if i can play ok daytime is PN doing summat to my connection, or is it BT having too many in my box ,
in my previous post it was asked if PN had done a line check ? adam or JoJo may look
but ther must be summat amiss somewhere .
please Help
Re: bad evening connection
03-01-2012 10:33 PM
Reason for asking is that if it drops too low the error rate on the connection can seriously muck up your gaming
03-01-2012 11:54 PM
The problems being worse for the last two nights might be a peculiar side effect from the data centre problems mentioned elsewhere. Hopefully the earlier hours maintenance due to start at midnight will return things to normal.
04-01-2012 8:29 AM
04-01-2012 9:36 AM
04-01-2012 9:46 AM
it sometimes affects TS3 also with connection lost
our game server Address: 193.93.45.87 Port: 25300
PS i have a modem sent to me for FTTC which i was told was available , but then told its not,, but got the modem isit possible to connect this to my present set up ?
04-01-2012 3:43 PM
Quote from: rongtw PS i have a modem sent to me for FTTC which i was told was available , but then told its not,, but got the modem isit possible to connect this to my present set up ?
I have a FTTC connection, but it appears the Huawei HG612 is set to auto-detect the type of connection.
I have seen evidence of one working straight out of the box on an ADSL2+ connection.
But, BT engineers usually bring the modem with them on the day of installation.
Are you really asking about the separate router that Plusnet send prior to FTTC's installation? - Mine is a Netgear WNR1000 v 3.
Paul.
04-01-2012 4:20 PM
04-01-2012 4:24 PM
Quote isit possible to connect this to my present set up ?
You can connect it to a modem or indeed another router but you may notice it doesn't have a DSL port so you can't connect directly to ADSL with it I'm afraid.
I'd probably advise trying another router if you are able to though.
Adam
04-01-2012 9:56 PM
this is what i have tried , too see if its at my end .
Dissable crossfire
set all graphics settings to low
drivers for GFX cards revert back to old version
reinstalled network drivers
swapped router
repair win 7 installation
unintall/reinstall punkbuster.
turn AV & firewall off
and i am still getting this
05-01-2012 8:08 PM
05-01-2012 9:55 PM
Quote from: rongtw had a quite good nite untill 20.00
and one game disconect at 21.25 so it looks like possible cause is overuse of my line too many people on the same line
09-01-2012 11:39 AM
Is that still happening? Looks from the test result on the ticket like things are alright, is there anyone else using the connection at your premises there whilst you're trying to play?
16-01-2012 9:48 PM
its still random but reseting the router clears it for a while some nights its fine all night but others its impossible
tonites stats
17-01-2012 11:26 AM
