WiFi Keeps Dropping
- WiFi Keeps Dropping
WiFi Keeps Dropping
06-07-2020 5:29 PM - edited 06-07-2020 5:29 PM
Message 1 of 3
(860 Views)
2 REPLIES 2
Re: WiFi Keeps Dropping
06-07-2020 10:41 PM
If a dual band router ensure you give the 5ghZ band a different SSID name.
D/load a free wifi analyser app, and check wht frequencies most in use in your locale.
Then choose the least/ not used wifi channels, by adjusting router.
5ghZ is currently less populated, has more channels, but has less range from router.
Message 2 of 3
(837 Views)
07-07-2020 12:33 AM
Many thanks Gel, I've done that and so far so good - will keep an eye on things over the next few days.
Message 3 of 3
(825 Views)
