What is a dropped connection?
- Re: What is a dropped connection?
- « Previous
- Next »
06-10-2007 10:21 PM
Do you ever hear any crackle on the phone line, that sounds like its due to a faulty joint?
Do you hear any hiss on the phone line, when you make a call?
I used to be able to hear the ADSL modem re-train. It sounds a bit like dial-upmodem buzz working through a sequence.
Does the new filter you have have four wires on the plug? These extend the bell wire, unfiltered. However, you house wiring has been disconnected.
My solwise filters and original 512K ADSL used to be very noisy,especially with a dect phone, off hook.
My line is crystal clear now.
07-10-2007 1:13 AM
07-10-2007 8:30 AM
So, do you think it's worth raising a fault with PN or just forget it?
07-10-2007 8:33 AM
Sorry if you've already mentioned this in the thread, but just for clarification
07-10-2007 9:47 AM
07-10-2007 9:59 AM
Hope you can get it sorted out
07-10-2007 10:20 AM
Quote from: flicker The router re-boots whilst I'm still on the call, it just disconnects for about 2 minutes in total, so it's only the act of actually answering the call that disconnects me from broadband.
Ring wire?
B.
07-10-2007 4:19 PM
I do still have my old Edimax router, so I'll have a go with that plugged in, but I don't think that will make a difference, as it was thought that was faulty in the first place, why I got another one. Oh and while I think of it, I also have a USB broadband modem, for using when we have power cuts (which happen fairly often, means I can still get online for a couple of hours until the laptop battery goes flat.... ) and that also drops the connection, I know that from before without getting that out again.
Oh and btw, I am a she not a he, not that it's important...
08-10-2007 11:58 AM
08-10-2007 10:30 PM
I was going to ask if the problem was at the start of ringing or when you answered, but I think you just answered the question. I will ask anyway.
If you ring your line with the mobile does your modem reboot when ringing started?
Does the modem hold up during ringing and only reboot when you answer the phone line? Let it ring for a minute or two before answering. When does it disconnect? Is it repeatable?
The answers may be of interest to BT.
Ringing applies a big voltage. It appears to be trashing the ADSL signal.
Ringing does not affect my line or ADSL signal.
08-10-2007 10:33 PM
08-10-2007 10:43 PM
Hope this helps, not sure if it's answered what you wanted to know though.
- « Previous
- Next »
