Very frequent DSL is Down messages
- Very frequent DSL is Down messages
18-10-2017 11:14 PM
Having just transferred from another BT Wholesale provider with no issues, I've had nearly a week of solid, reliable connectivity, but a few days ago, the internet connection drops out very frequently, every 10 / 20 seconds or so. I've done the usual debugging, microfilters, adsl cable change, master socket and none of this makes any difference. It was fine over the weekend, 2 disconnects, but since then, its gone crazy mad. Line tests through support team show no faults, I cant see anything in terms of logs from the F2704N router, but see people on here have had a similar issue both with Broadband (as in my case) and Fibre.
I'd be interested in knowing if anyone could point me in the right direction of something to try as its pretty much useless at the minute. I've an engineer booked in november, but no internet between now and then will be incredibly painful! I've tried just running the wifi, no ethernet connections and direct into the master socket and I'm currently connected for 16 mins (I've had several disconnects making this post!)
Re: Very frequent DSL is Down messages
19-10-2017 3:26 PM
Intermittent connections can be caused by a wide range of factors, so a solution from one person is very unlikely to be the same for another.
Have you been through the troubleshooting and reported a fault using the links Adam provided on a different thread you've responded on?
19-10-2017 7:32 PM
Got another modem today so will try that as I wonder if it's a dodgy unit or setting, even though I've factory reset a few times.
19-10-2017 10:14 PM
Index Time Type Level Content
1 2017-10-19 22:10:40 PPP Information ppp0 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x96998752>]
2 2017-10-19 22:10:39 SYSTEM Notice DSL link down
3 2017-10-19 22:10:37 PPP Information ppp0 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x96998752>]
4 2017-10-19 22:10:34 PPP Information ppp0 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x96998752>]
5 2017-10-19 22:10:31 PPP Information ppp0 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x96998752>]
6 2017-10-19 22:10:25 SYSTEM Notice DSL link up
7 2017-10-19 22:10:25 SYSTEM Notice DSL training G.992 exchange
8 2017-10-19 22:10:19 SYSTEM Notice DSL training G.992 channel analysis
9 2017-10-19 22:10:14 SYSTEM Notice DSL training G.992 started
10 2017-10-19 22:10:05 SYSTEM Notice DSL training G.994
11 2017-10-19 22:10:01 SYSTEM Notice DSL training G.992 exchange
12 2017-10-19 22:09:55 SYSTEM Notice DSL training G.992 channel analysis
13 2017-10-19 22:09:50 SYSTEM Notice DSL training G.992 started
24-10-2017 1:07 PM
Hi, I've just dropped you a reply here: https://community.plus.net/t5/Broadband/DSL-is-down/m-p/1485148#M318533
