VPN and TG582n Router
- Re: VPN and TG582n Router
- « Previous
- 1
- 2
- Next »
24-02-2012 5:31 PM
Anyway , glad you got it to work, happy to have helped.
12-08-2012 7:14 PM
Hi - this is exactly the problem I'm having with my VPN
I have tried to run the CMD as suggested by Mr W but I get a response of "failed to delete CONN binding"
Any suggestions??
12-08-2012 8:34 PM
I now have a working VPN connection!
Thanks.
13-05-2014 2:26 PM
I am having exactly the same problem, when trying to Unbind IKE i'm getting "failed to delete CONN binding" - - how did you manage to solve this, or is this a standard response from the router?
Cheers
03-03-2016 11:08 AM
Started a new topic but plusnet have just come out with the same line of no VPN support.
My work have told me that BT or Plusnet have changed settings causing issues with this.
I've tried the first step above but when trying to enable telnet i get the attached error.
"windows couldnt complete the requested changes
the function attempted to use a name that is reserved for use by another transaction
error code: 0x80071a90
03-03-2016 11:28 AM
03-03-2016 11:39 AM
cannot open connection to the host on port 23 connection failed
03-03-2016 12:12 PM
really getting frustrated. vpn was 100% fine up until jan 3rd therefore it is a PLUSNET ISSUE and neither plusnet nor my works IT (who have encountered the problem before) are willing to help.
- « Previous
- 1
- 2
- Next »
