Throughput speed
- Throughput speed
Throughput speed
18-09-2010 5:28 PM
Thanks in advance for any help.
DSL Connection
Link Information
Uptime: 3 days, 6:16:00
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 440 / 7,115
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 20.0 / 43.5
SN Margin (Up/Down) [dB]: 26.5 / 12.0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 3,807,058
CRC Errors (Up/Down): 0 / 305
HEC Errors (Up/Down): 0 / 287
Re: Throughput speed
18-09-2010 6:17 PM
Your profile is set at 5500 with BT so there's nothing we can do to lift that. It will be done by their systems as long as the sync rate stays up.
Jojo
18-09-2010 6:32 PM
Link Information
Uptime: 24 days, 2:55:06
Bandwidth (Up/Down) [kbps/kbps]: 440 / 7,880
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 4.00
SN Margin (Up/Down) [dB]: 26.0 / 9.0
Loss of Signal (Local/Remote): 11 / 0
Error Seconds (Local/Remote): 36 / 0
FEC Errors (Up/Down): 0 / 3,246,538
CRC Errors (Up/Down): 0 / 7,570
HEC Errors (Up/Down): 0 / 5,766
18-09-2010 6:38 PM
Kitz gives an idea here about how long it can take. I'll run a line check now and see what I can see, but it can take up to 15 mins for an ADSL2+ report. I'll get back to you soon on that.
Jojo
18-09-2010 6:45 PM
18-09-2010 6:46 PM
18-09-2010 6:50 PM
18-09-2010 7:06 PM
Your current sync rate is 7115 so that will bring it up to 6000 when it lifts.
Jojo
18-09-2010 7:08 PM
18-09-2010 7:23 PM
20-09-2010 2:45 PM
DSL Connection
Link Information
Uptime: 5 days, 3:38:38
SN Margin (Up/Down) [dB]: 25.5 / 11.5
Error Seconds (Local/Remote): 2 / 0
FEC Errors (Up/Down): 0 / 3,853,442
CRC Errors (Up/Down): 0 / 438
HEC Errors (Up/Down): 0 / 409
20-09-2010 3:38 PM
I've just nudged it up to 6000 for you. You'll see the difference shortly.
Jojo
20-09-2010 4:26 PM
20-09-2010 4:35 PM
