Thomson router AAAGH!!!!!
- Thomson router AAAGH!!!!!
04-04-2010 1:48 PM
It will connect through LAN no problems, and connected my HTC without a hitch, but will it connect to Vista... oooh no!!!
I can see the network available but it will not connect. Just says 'there is a problem'. But what problem? thanks a lot Microsoft! Every time I try to connect it knocks the internet off for a short time too. I have given up trying now as I don't know what could be done differently. Its not an internet problem as it works wired.
This is my second Thomson, the first died recently and I got that one connected somehow after 2 days of trying. If i cant find a solution its going for a Netgear. Been looking at the DGN3500 >>> anyone have any experience with this router?
Re: Thomson router AAAGH!!!!!
04-04-2010 2:05 PM
04-04-2010 2:10 PM
04-04-2010 4:26 PM
04-04-2010 5:53 PM
try what pierre has come up with by going to control panel- network and internet- network and sharing centre and then goto i think manage wireless connections
04-04-2010 6:18 PM
04-04-2010 7:51 PM
04-04-2010 9:39 PM
At first I naturally blamed it on something they had done, but that wasn't the case.
It has been three weeks now, numerous calls to plusnet and I have exhausted all ideas. I have tried it with no encription (later plusnet support suggested changing the encription would fix it, but of course it didn't as i had tried it with no encription beforehand. I have tried resetting the router, removing the static IP address, using windows inbuilt trouble shooter. Trying every single combination of settings possible, changing the name and details of the wireless connection, plugging the router into the main line and removing all other connections including phones. Etc. Using an old router (didn't work at all unfortunatley).
Now of course they want to change ISP, as they can't connect to the internet.
I have no idea what steps to take.
Nothing can connect to the wireless,
A pc using windows 7, a laptop using windows xp and wii/xbox etc. So it is definatley a router problem not the connecting machines.
I am running windows 7 on this.
Ethernet is fine, only wireless will not connect.
Could someone suggest a decent router that will work with plusnet? This thomson rubbish really does not do plusnet proud.
04-04-2010 9:47 PM
My Thompson is over a year old now and still working OK. Wireless to this Machine on Win 7, a netbook - xp sp3, a netbook on linux, A widescreen lapton on XPsp3 occasionally and an Archos on what ever that is all at the same time, and occasionally a non wireless laptop on ethernet
05-04-2010 12:27 AM
FWIW, MAC Address filtering is easily spoofed so is nor really worth implementing.
05-04-2010 5:48 PM
it was the wireless Sky TV transmitter interfering with the wireless signal.
09-09-2010 10:35 AM
Basically, I persueded my GFs mum to switch from BT broadband to PlusNet
Every time it connects to the wifi it never seems to get an IP address from the router, so sits there using the MS designated 'private' IP address and essentially won't communicate with the network at all. After several hours of googling, checking settings and resetting things, I tried changing the wireless encryption from WPA-PSK to WEP and it seems to have done the job.
Obviously the network is less secure now, but this house has thick walls and I think you'd have a job getting much signal outside anyway.
Two questions to PlusNet would be: Is this a known issue with the Thomson 585v7 router and Vista? AND Giving the high usage of Vista, especially amomg home users, do PlusNet not think this issue should be addressed?
James
Ex PlusNet Customer
Perpetual PlusNet Promoter
09-09-2010 11:09 AM
Quote from: Toffeegerbil
I had exactly the same issue, when I turned the sky video sender off it all sprang back into life luckily the sky sender has 5 different channel settings so I changed to a different channel and now no problems..and actually a better telly picture upstairs
