Technicolor TG582n & Multiasking
- Technicolor TG582n & Multiasking
Re: Technicolor TG582n & Multiasking
14-01-2013 10:18 PM
Inbound looks like it is wrong. Zip up the wireshark capture then go to https://portal.plus.net/wizard/?p=wizard&page=22451&wizard_id=38 and raise a ticket attaching the zip file. It's probably a good idea to post the ticket number back here.
15-01-2013 1:39 AM
Thanks for everyones help!
15-01-2013 12:09 PM
Plusnet Technology
15-01-2013 4:23 PM
15-01-2013 4:42 PM
Ex-Broadband Service Manager
15-01-2013 4:46 PM
15-01-2013 6:49 PM
The bottleneck is the connection between you and the exchange so QoS has to be done by the device sending the data across the bottleneck. So for downstream that is done at the Plusnet end by putting the traffic in to the different queues, for upstream it would have to be done by your router.
If you can set up QoS on the TP Link, why don't you try using that (unless it's locked to your previous ISP)?
16-01-2013 7:16 AM
Quote from: jelv If you can set up QoS on the TP Link, why don't you try using that (unless it's locked to your previous ISP)?
Ahh great! I thought it had an effect when I did try it before.
The problem I have though is, I can't use my old tplink as theres a fault when it pairs with a range extender of mine.
Is there a way to set up QoS on the technicolor then?
Is there any explanation as to why I have this call quality problem with the technicolor and not my old TP-Link? I don't want to switch the modem/routers over at the moment as I am in my training period. But with my old ISP: Xilo. There was never an issue such as this, even when there were no QoS rules set.
16-01-2013 9:58 AM
Is this normal and would this be the same as what happens with Skype?
Perhaps the rule used to prioritise upload exceeds that of Skype?
17-01-2013 2:12 PM
Quote from: Kelly I think we know why, it will be to do with maxing the upstream. Need the QoS rule I think on the router.
How can I make the rule on the technicolor?
18-01-2013 5:15 PM
Which one is it??
18-01-2013 5:15 PM
18-01-2013 5:34 PM
http://download.modem-help.co.uk/mfcs-A/Alcatel/Modems/TG582n/v1/Manuals/Application-Notes/IP-QoS-Co... but it doesn't look simple
18-01-2013 6:01 PM
http://www.technicolorbroadbandpartner.com/getfile.php?id=6284
(From the Technicolor TG585n page)
18-01-2013 11:04 PM
I wish plusnet provided a gui for this, but its still very strange this is a problem for me compared to my old router.
