TG585v7 forgets my lan connections when "New Stations Are Not Allowed" is set.
- TG585v7 forgets my lan connections when "New Stati...
Re: TG585v7 forgets my lan connections when "New Stations Are Not Allowed" is set.
29-07-2009 8:47 AM
Quote from: Jameseh The WPS button does not currently function and will not do so until the v8 firmware has been released.
We don't currently have a date for an expected release.
I have a beta release of the version 8 firmware. I'll see if I can get round to installing it on a device today to test the WPS functionality. I've a few of these units at home and I've never known the LED light on the WPS button to do anything so I'd be surprised if your device is faulty.
Quote from: Agent47 Hi, I'm having a few problems with a new router from Plusnet (replacement for old D-Link router), the Thomson TG585v7.
The first problem is how do I switch to "New Stations Are Not Allowed" on the Wireless Access Point security screen without locking out all my wireless LAN connections(PC, Laptop and Nintendo DS, all setup and given there own IP addresses on the Local Network Devices screen)?
puddy's reply here (which I'm inclined to concur with) would suggest that you can't.
Quote from: Agent47 the second problem is about port forwarding; the port I used to P2P with my old router (port 52000) no-longer works with the new one. I set up a rule for the P2P TCP port on the Game or Application Definition screen but the P2P application reports my connection as being "Firewalled". I have the Plusnet and Comodo firewalls switched on, and MS Windows firewall switched off -as with my old Router setup- with the only difference being the new TG585v7 router.
What level is the Plusnet firewall set to and have you tried turning it off? Have you remembered to assign the rule to a local device on your network? Have you tried forwarding UDP traffic as well?
29-07-2009 9:41 AM
http://community.plus.net/library/
There's absolutely nothing to prevent you from starting a page off with one feature that you've found to work, submit that and let the community build on it. A 'Support Library' help page doesn't have to be complete. To kick things off you could create a blank support page being created that said 'Help needed' with security, wifi button on the front etc.
29-07-2009 10:28 AM
Started by gathering together material from various places - as soon as I have something worthwhile - I'll start putting it on community.
A major find today has been :
http://www.thomsonbroadbandpartner.com/dsl-modems-gateways/products/product-detail.php?id=161
not sure why I hadn't found it before ! ?.
29-07-2009 10:28 AM
Quote from: Peter I know Mal mentioned this on the first page but I'd just like to suggest that if there are features of any of the hardware we supply or that use that aren't documented by our support pages, or supported by the support agents, that you can use the Support Library to create a 'community driven' support page:
I wrote this one a while back
29-07-2009 10:43 AM
29-07-2009 11:38 AM
My original fault with port forwarding lay, I finally discovered, with my software firewall, Comodo. It was blocking the new network until I configured some new rules for ports on the new IP addresses on the TG585v7 network. Up until then, I'd only configured the applications.
I'd be interested in finding out if the WPS feature is linked to the MAC blocking on the Wireless Access Point config. screen.
31-07-2009 3:45 PM
Quote from: mal0z Any idea when v8 will be released by Thomson and then PN configure it for their branded release please Bob ?.
No idea on the release date. There's still a few problems with the v8 build that we'd like to see fixed before it's released. The copy I have is already PN branded so that part should be trivial once it's available for mass distribution. Having said that...
Quote from: Bob
I tried testing the WPS functionality with software version 8.2.3.10 earlier today. Unfortunately there seemed to be no change from the previous firmware builds i.e. no LEDs on the WPS button and the 'new stations allowed with registration' functionality remained broken.
31-07-2009 3:49 PM
31-07-2009 5:39 PM
20-08-2009 7:30 PM
I'm keen to make my wireless connection as secure as possible and hopefully v8 firmware might allow this.
Thanks in anticipation.
dick:quote
21-08-2009 1:51 PM
Bob's been given a v8 new Thomson Router, but he's away for the weekend and early next week.
I'll try to remember to ask him when he gets back on Wednesday.
08-09-2009 5:31 PM
..........still waiting for a response from Bob!
09-09-2009 11:10 AM
I did try again but still couldn't get the blighter to work using v8 firmware on the 585v7. As James has mentioned I do now have a beta 585v8 in my possession but I haven't yet got round to seeing if WPS works or not. Even if it does the 585v8 runs on different hardware so the findings wouldn't be of much use to you.
12-09-2009 6:23 PM
I’m not impressed and feel poorly served by Plusnet.
12-09-2009 8:44 PM
Note that this seems to be a Thomson policy as SNMP has also been removed from 7.x firmware versions for the older 780WL (and probably others as well). I suppose SNMP isn't such a priority for Thomson's clients (ie the ISPs) now that TR069 is coming to the fore.
