TG582n Router Firmware Help - Hopefully to fix rebooting.
- Re: TG582n Router Firmware Help - Hopefully to fix...
02-01-2014 3:53 PM
I currently have a TG582n running 8.C.M.0 on FTTC.
It is rebooting at least once or twice per day - very annoying.
I've considered trying a firmware upgrade to the latest version (10.2.5.2) - but I'm unable to upgrade the firmware myself as I don't have access to a copy of windows.
Can one of the Plusnet team please push a firmware update to me? I'd like to see if that helps before I throw this router out the window
Many Thanks,
-R-
Many Thanks,
-R-
Message 1 of 5
(1,580 Views)
4 REPLIES 4
Re: TG582n Router Firmware Help - Hopefully to fix rebooting.
02-01-2014 4:47 PM
Hi, just asked our products team to have a look at this for you, it should be done shortly.
EDIT: Apologies, looks like we're not able to do it right now but will make sure it's looked at tomorrow for you - I'll pop back to this thread then.
Message 2 of 5
(476 Views)
03-01-2014 5:59 AM
Thanks Matt.
I'll keep an eye out for something today
Message 3 of 5
(476 Views)
03-01-2014 10:26 AM
Just had confirmation that it's been updated for you, hope it makes a difference - please let us know
Message 4 of 5
(476 Views)
04-01-2014 4:47 PM
I can see that the update has been applied successfully - now on 10.2.5.2.FO thanks!
Unfortunately, still getting router resets - the current uptime on my router is 2hrs 40mins
Anyone got any other ideas to try?
Message 5 of 5
(476 Views)
