Stuck profile
- Re: Stuck profile
Stuck profile
07-01-2010 11:55 AM
After a power cut on New Years' Eve, my router is reporting a sync speed of 2100+ kbps. I have been unable to run the BT speedtester, but I would have expected that my profile would have increased to 1750kbps by now. My current PN profile is 1500.
I would appreciate it if someone at PN could check this, and if warranted give my profile a bit of a nudge.
Thanks in anticipation.
My other car isn't a Ferrari
Message 1 of 6
(1,026 Views)
5 REPLIES 5
Re: Stuck profile
07-01-2010 1:01 PM
I'll go check now for you and get back shortly.
Message 2 of 6
(482 Views)
Re: Stuck profile
07-01-2010 1:07 PM
Yep, it's upped to 1750 now, I'll up it on our side.
I've also found the reason your account wasn't updating correctly, for some reason the circuit identifier we had stored was incorrect. This looks to have changed from what we had stored, I've updated it and hopefully that'll mean the line profile will update itself from now.
Message 3 of 6
(482 Views)
Re: Stuck profile
07-01-2010 1:26 PM
Thanks Chris, very pleased with such a quick response from you. Just out of interest, what is the 'circuit identifier', and why does/should it change?
Message 4 of 6
(482 Views)
Re: Stuck profile
07-01-2010 1:31 PM
It only normally changes when the line is moved or if you migrate out/back in.
http://en.wikipedia.org/wiki/Consumer_Broadband_United_Kingdom
Message 5 of 6
(482 Views)
Re: Stuck profile
07-01-2010 1:36 PM
Thanks again, Chris
Message 6 of 6
(482 Views)
