Still no Broadband following Edinburgh outage
- Still no Broadband following Edinburgh outage
- « Previous
- Next »
Re: Still no Broadband following Edinburgh outage
23-11-2010 9:47 AM
Do you have another router you can try, have you changed the filter?
Jojo
23-11-2010 11:49 AM
I am sure when I last had major problems in January the last faceplate / fitment on was one where a filter for the router was not required. i.e. it was an integral part of the faceplate / fitment. I can try with a filter though.
Another router was tried earlier (during this set of problems) when BT guy was here, but as I was at work I don't know what the result was. I suspect he was only looking for a connection anyway and not interested on the download speed.
I will try to find another router again, (somewhere in the loft) asap.
23-11-2010 11:51 AM
Yes, I'd be interested to see the results with a standard filter in the test socket.
Jojo
23-11-2010 11:53 AM
23-11-2010 11:54 AM
23-11-2010 2:44 PM
Thanks, I'll probably be on later tonight.
Jojo
23-11-2010 7:01 PM
23 Nov 2010 @ 06:35 (Belkin G Router) After Further Re-Boot
ADSL
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate (Kbps) 1248Kb 448Kb
Noise Margin 5 19
Output power (dBm) 123 164
Attenuation (dB) 65 31
BT Speed Tester - Will not run
My Broadband Speed Checker
Date Download Speed Upload Speed
23 Nov 10 19:00 691 kbps (86.4kB/s) 374 kbps (46.8kB/s)
Duh!
24-11-2010 6:44 AM
24 Nov 2010 @ 06:41 (Belkin G Router)
ADSL
Status SHOWTIME
Downstream Upstream
Noise Margin 7 19
BT Speed Tester
Download speed achieved during the test was - 615 Kbps
Acceptable range of speeds is 200-1000 Kbps.
DSL Connection Rate :1248 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 750 Kbps
24 Nov 10 06:43 690 kbps (86.3kB/s) 371 kbps (46.6kB/s)
PN IP Profile 750Kbps
24-11-2010 7:35 AM
25-11-2010 1:12 PM
25-11-2010 2:09 PM
Just done a line test and you're still syncing at 1248k 8dB SNR, I'm at a loss how we can improve it.
Jojo
25-11-2010 5:45 PM
25 Nov 2010 @ 17:30 (Belkin G Router)
ADSL
Status SHOWTIME
Downstream Upstream
Noise Margin 6 19
BT Speed Tester
Download speed achieved during the test was - 852 Kbps
IP Profile for your line is - 1000 Kbps
24 Nov 10 17:34 927 kbps (116kB/s) 374 kbps (46.8kB/s)
PN IP Profile 1000Kbps
At least now we are back to what I had before the outage, shame it's not as good as it was last Feb, but perhaps a reboot at a better time of day may help, provided if it resyncs higher, it can maintain that! Ever hopeful.
25-11-2010 5:58 PM
Glad there's some improvement.
Jojo
- « Previous
- Next »
