Speeds slow and then pickup on reconnect
- Speeds slow and then pickup on reconnect
17-08-2007 1:10 PM
My connection (8 mbit) has a reasonable speed if I reset my router, but then gradually slows down to about 500kbps. Could this be a problem with my router (just updated the firmware and erased all config settings and re-configured), my comp or maybe the connection. Any ideas anyone?
Message 1 of 3
(1,389 Views)
2 REPLIES 2
Re: Speeds slow and then pickup on reconnect
17-08-2007 8:51 PM
It's a netgear wireless ADSL firewall router DG824G. I connect to the net with my router and then wirelessly from my comp to the router. My OS is vista. It's not a problem with comms between comp and router, I'm sure of that. As for stats, as I said in my first post I just wiped everything so I don't have any.
Message 2 of 3
(388 Views)
18-08-2007 7:49 PM
The line stats should be available as soon as it rebooted and connected.
Its the line attenuation and SNR/Margin for both up and down we need.
Message 3 of 3
(388 Views)
