Speed terrible today..
- Speed terrible today..
23-11-2010 11:46 AM
i went to check what gateway i was on see if its an issue and i get this "Sorry, records show your IP address is not from the Plusnet brand and as such, we cannot detect your gateway." ????
Re: Speed terrible today..
23-11-2010 11:57 AM
If you open a command window and do a tracert to bbc.co.uk the second line should give you your gateway.
Here's mine on ptn-ago3
Tracing route to bbc.co.uk
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms gateway.gateway [192.168.1.254]
2 16 ms 15 ms 15 ms lo0-central2.ptn-ag03.plus.net [195.166.130.11]
3 31 ms 15 ms 15 ms gi2-13-321.ptn-gw01.plus.net [84.92.2.57]
4 15 ms 14 ms 14 ms po6.thn-gw1.plus.net [212.159.1.136]
5 15 ms 15 ms 14 ms po4.thn-gw2.plus.net [212.159.1.135]
6 15 ms 15 ms 14 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 15 ms 15 ms 15 ms 212.58.238.149
8 14 ms 15 ms 15 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
23-11-2010 11:59 AM
23-11-2010 2:16 PM
so can someone who knows tell me have i been capped or sumit??? or is there something up?
23-11-2010 3:40 PM
it just seems to me like its been capped? :S at 1mb, or is there a big fault, cuz from a constant 5-6mb to that is horrible
23-11-2010 4:15 PM
Your connection logs below show some disconnections which have probably caused your IP profile to go down to 750k which is why you're getting slow speeds. Are you aware of what caused these disconnections? Your sync rate is now 8128 so, if there are no more disconnections, it won't be too long before your profile goes back to 7150k, I'll keep an eye on it for you and make any adjustments necessary.
Jojo
23-11-2010 4:22 PM
23-11-2010 4:31 PM
we would normally quote 72 hours for it to lift but with such a big increase expected I have seen it change within hours, just don't disconnect anymore.
Jojo
23-11-2010 4:38 PM
23-11-2010 4:52 PM
Forgot to attach the visual before. I would definitely say it is much better to leave your router on all the time. I can't remember the last time I switched mine off.
Jojo
23-11-2010 5:21 PM
23-11-2010 8:34 PM
24-11-2010 9:47 AM
I notice that you're still disconnecting. Are these due to you rebooting or are you not aware of them?
Jojo
24-11-2010 10:48 AM
24-11-2010 2:01 PM
