Speed profiles on fibre
adamwalker
Fixes: 221
Hi all,
Please be aware that once your service is active, the speed profile will be set manually after we've checked and confirmed that the order has completed.
With that in mind, please do contact us if this isn't done within 24 hours of activation.
Thanks,
Adam.
 Adam Walker
4 REPLIES 4
ipclark
Re: Speed profiles on fibre
Thanks Adam,  mine was installed this morning so I'll try really, really hard to not chase anyone until tomorrow Wink  I remember using dial-up 28.8k connections so I can live with 6674kpbs for one more  day....Cheers.
johnboy999
its been  day and a half and no reply to the ticket #41120349, stuck at the pre existing speeds (5mb).
could a CS rep give this a nudge please?
ticket #41120349
ta
adamwalker
Fixes: 221
FYI all, As the trial is over I'm asking for this thread to be moved to broadband and routers. Please raise a new post rather than reply to this one if you need to ask for a profile update.
 Adam Walker
Fixes: 1,485
mod:note
locked so you have to post a new thread Wink
