Speed fallen below 1mbps!
- Speed fallen below 1mbps!
Re: Speed fallen below 1mbps!
19-11-2010 7:03 PM
Regards, Neil.
19-11-2010 7:10 PM
Do you switch your router off regularly? Have a look at the visual and see if you recognise any of the disconnections to be ones you instigated. Also. I've just ran a line test and your Ip profile is now up to 3000k
Jojo
21-11-2010 10:15 AM
21-11-2010 12:46 PM
Award winning customer service - "my ar$e"
21-11-2010 1:09 PM
According to the latest update our supplies think your fault is resolved. Are you still in the test socket, as your sync rate is still only around the 1200 mark.
Jojo
21-11-2010 1:11 PM
I've just ran a line test and the sync rate is only 320k. Are you plugged in to the test socket at the moment?
Jojo
21-11-2010 3:26 PM
Thanks for a response.
Declan
21-11-2010 5:18 PM
I appreciate you've not changed the set up but if you could plug into the test socket for me then I can run another line test and we could get a head start on pinpointing the problem.
Jojo
21-11-2010 7:14 PM
21-11-2010 7:19 PM
I can certainly look into it more for you. Even though your sync is now higher you will still have to wait for your IP Profile to pick up.
Jojo
22-11-2010 7:09 PM
22-11-2010 7:35 PM
Quote from: declan Award winng service???? I'll be pleading with Sky to have me back! Logged a job on Tuesday to complain about my speed and not heard a thing - Plusnet have obviously taken umbridge as they've downgraded my speed to 320KBS. Having one of those moments thinking -" why oh why did i switch", Sky's 13ppm call charges look attractive right now. When I signed up 3 weeks ago I was bombarded with messges that meant nothing, now i'm signed up its a 30min + wait to speak to someone.
Hahaha thanks for that I had a right old chuckle over this comment! But yea I couldnt agree with you more at this very moment in time
23-11-2010 3:51 PM
the line's looking stable now, I could always try an SNR reset to bring it back down to 6dB, which would probably lift the sync rate. Let me know if you want me to do it. It could well work but I can't guarantee the SNR won't go up again.
Jojo
23-11-2010 4:57 PM
23-11-2010 5:32 PM
These disconnections today have caused the profile to drop to 135k. If you're not sure why the line is dropping then you need to raise a fault.
Jojo
