Speed Survey By The Gadget Show
- Speed Survey By The Gadget Show
Re: Speed Survey By The Gadget Show
13-11-2007 7:29 PM
13-11-2007 8:13 PM
Quote from: jmd ...if you are using a wireless router does that alter the sort of speed you get? before I went wireless I used to have higher speeds.......
It can do - depends on the speed of your wireless.
It's possible for wireless to run as slow as a claimed 1Mb/sec - although data rates will be even less than this, especially if you are getting errors and consequent retransmissions.
14-11-2007 4:11 PM
Plusnet Technology
14-11-2007 4:23 PM
14-11-2007 9:26 PM
947 Down and 374 Up - MyBroadbandSpeed.co.uk
946 Down and 372 Up - Speedtest.net
...could be a lot better...
15-11-2007 9:50 AM
MrZeno,
I've run a test on your line and BT have applied a 1250Kbps profile against your line. I've bumped your profile a little at this end and you might be able to tweak a little bit extra out of your line by rebooting your modem or router.
The main problem you have is that you're a considerable way away from your exchange, which unfortunately I cannot do anything about
15-11-2007 10:57 AM
Quote from: Jameseh The main problem you have is that you're a considerable way away from your exchange, which unfortunately I cannot do anything about
You mean you'll not help me move house, some nice ones near the exchange and I'm after a four bedroom house
16-11-2007 7:35 AM
I have been trying to try the GS speedtest from about 05:30AM this morning, it seems down as it is just waiting for lon.speedtest.net to reply! I give up now.
SW.
3Mb FTTC
16-11-2007 7:40 AM
16-11-2007 2:46 PM
16-11-2007 4:23 PM
16-11-2007 4:50 PM
16-11-2007 5:09 PM
16-11-2007 5:13 PM
I've amended your profile to 6500Kbps, but I suspect it won't make much difference.
16-11-2007 5:21 PM
Quote from: Jameseh Hi there,
Sorry, James. I didn't ask the question I meant to. What I was asking is can my profile be adjusted higher?
What was it before you adjusted it?
Sorry for the confusion.
artmo.
