Some websites have stopped loading
- Re: Some websites have stopped loading
19-05-2017 6:21 PM
Since yesterday, suddenly some websites started to fail to load, whilst other websites load OK.
In Safari the blue progress bar starts to move and then halts. Nothing is ever displayed.
In Firefox, the “Connecting…” message appears, but nothing ever happens.
This is happening in Firefox and Safari on all our computers.
Clearing browser caches makes no difference.
Rebooting the router makes no difference.
If I connect to a VPN, then all websites load OK.
Overriding the default Plusnet DNS servers to be GoogleDNS or OpenDNS (on a computer locally, or on the router) makes no difference.
Example websites that fail to load:
http://www.rightmove.co.uk
http://www.thompson-morgan.com
Does anybody have any ideas as to what to try next to get it to work, or what the cause might be?
Given that changing the DNS server doesn’t fix it, but going via a VPN does fix it, does that imply there is some problem with PlusNet’s connections to those websites? If so, then there’s nothing I can do to fix it, except report it to PlusNet.
19-05-2017 6:32 PM
Both those sites load ok for me using a PN connection. Not much help but it least it shows it isn't a Plusnet-wide issue.
I'm using Google DNS servers:
8.8.8.8
8.8.4.4
Forum Moderator and Customer
19-05-2017 6:38 PM
Both of those links opened for me. Using Google and Hub1, so not a PN fault.
Growing old is inevitable...But growing up is optional.
19-05-2017 7:29 PM
Are you experiencing any other issues with your connection? I ask as you seem to have disconnected quite frequently this afternoon/evening:
19-05-2017 7:52 PM
I've rebooted the router 2 times today. I've also changed various settings on the router (DNS etc) so maybe that caused a reconnection (but I don't think those setting do cause a reconnection).
I did change the MTU setting about 5 times (to try and get traceroute to give more info) - I wonder if this causes a reconnection? The MTU is back at the original setting now: 1458.
19-05-2017 8:16 PM
19-05-2017 9:03 PM - edited 19-05-2017 9:04 PM
Router: NetGear DG834pn
OS: OS X 10.7.5, OS X 10.11.6, iPhone with IOS 10.1.1 using wifi. The sites don't load on all these.
Sites that don't load: rightmove.co.uk www.thompson-morgan.com taxresearch.org.uk
taxresearch.org.uk is probably the best example for testing, because it is a simple site/server with static IP/domain. rightmove.co.uk has some kind of dynamic server allocation (the domain DNS seems to be updated every few minutes!) and www.thompson-morgan.com seems to have 3 IP addresses associated with it.
If I connect via a VPN (using the same DNS server at the VPN), or using mobile data on iPhone, all sites work OK.
Ping:
rightmove.co.uk and www.thompson-morgan.com always timeout. (Probably the servers don't respond to ping?)
taxresearch.org.uk pings correctly.
Traceroute:
traceroute to rightmove.co.uk (146.101.19.102), 64 hops max, 72 byte packets
1 192.168.0.1 (192.168.0.1) 1.300 ms 0.778 ms 0.733 ms
2 lo0.central10.psb-bng02.plus.net (195.166.130.253) 37.278 ms 27.188 ms 26.097 ms
3 411.be6.psb-ir01.plus.net (84.93.253.107) 26.692 ms 26.390 ms 26.774 ms
4 195.99.125.134 (195.99.125.134) 26.527 ms 26.345 ms 26.272 ms
5 peer1-et-2-1-0.telehouse.ukcore.bt.net (62.172.103.25) 27.128 ms 26.875 ms 26.829 ms
6 * * *
7 146.101.1.61 (146.101.1.61) 27.537 ms 27.040 ms 26.682 ms
8 146.101.1.62 (146.101.1.62) 30.538 ms 28.795 ms 27.375 ms
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
Never completed after 10 minutes
traceroute: Warning: www.thompson-morgan.com has multiple addresses; using 34.250.52.249
traceroute to prod-t-and-m-lb-37216428.eu-west-1.elb.amazonaws.com (34.250.52.249), 64 hops max, 72 byte packets
1 192.168.0.1 (192.168.0.1) 1.229 ms 0.810 ms 0.758 ms
2 lo0.central10.psb-bng02.plus.net (195.166.130.253) 26.916 ms 26.505 ms 25.768 ms
3 411.be6.psb-ir02.plus.net (84.93.253.111) 25.933 ms 27.049 ms 26.156 ms
4 195.99.125.138 (195.99.125.138) 26.117 ms 26.627 ms 26.286 ms
5 peer1-hu0-9-0-2.slough.ukcore.bt.net (62.172.103.153) 28.935 ms 28.093 ms 28.362 ms
6 109.159.253.105 (109.159.253.105) 27.940 ms 28.186 ms 28.325 ms
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 178.236.0.109 (178.236.0.109) 38.949 ms 36.920 ms 37.483 ms
15 * * *
16 * * *
Never completed
traceroute to taxresearch.org.uk (217.160.223.242), 64 hops max, 72 byte packets
1 192.168.0.1 (192.168.0.1) 1.320 ms 0.833 ms 0.743 ms
2 lo0.central10.psb-bng02.plus.net (195.166.130.253) 26.071 ms 32.482 ms 27.408 ms
3 411.be6.psb-ir01.plus.net (84.93.253.107) 26.257 ms 26.257 ms 26.571 ms
4 195.99.125.134 (195.99.125.134) 26.462 ms 26.536 ms 26.269 ms
5 peer1-xe0-1-1.faraday.ukcore.bt.net (213.121.193.205) 26.735 ms 27.126 ms 26.475 ms
6 * * *
7 ae-0-0.bb-a.ba.slo.gb.oneandone.net (212.227.120.105) 28.180 ms 27.328 ms 27.204 ms
8 ae-11-0.bb-a.fra3.fra.de.oneandone.net (212.227.120.154) 40.440 ms 39.490 ms 39.815 ms
9 ae-1.bb-c.act.fra.de.oneandone.net (212.227.120.90) 40.273 ms 77.636 ms 40.835 ms
10 ae-11.bb-c.bs.kae.de.oneandone.net (212.227.120.18) 51.230 ms 49.082 ms 49.943 ms
11 kundenserver.de (217.160.223.242) 42.301 ms 42.309 ms 42.039 ms
It arrived at the IP of the domain!
19-05-2017 11:27 PM
20-05-2017 9:50 AM
Testing your line I'm seeing the signal to noise ratio at 3db which can cause a variety of problems.
Once our suppliers finish the maintenance they are currently performing on their systems, I'll process a DLM change to move the target to 6db to see if that helps. Should be around 5pm.
20-05-2017 11:40 AM
It doesn't seem likely that the target SNRM, or anything else affecting the DSL, will affect some websites but not others.
Perhaps check the router's log to see if there are any log entries corresponding to the times you attempt to access the websites that don't load.
20-05-2017 1:04 PM
@ejs,
Do the incomplete tracert results tell us anything ... such as problems with routing / transit peers?
20-05-2017 1:26 PM
Not really, because I can access the sites and the traceroutes look much the same.
20-05-2017 5:19 PM
I have found out that the problem is something weird on the router, and managed to get things working, but not sure why yet!
The router settings hadn't been changed for years before the problems started, but I went through all of the settings on the router to see if I could find anything that would change the problem.
There were 2 outbound firewall rules for http and https, which were set up to ALLOW all LAN addresses to connect to all WAN addresses, (i.e. they should ALLOW all web traffic out, as if the rules weren't defined). If I disable these rules, everything works OK.
These rules were created years ago and have been turned on for years, so no idea as to why they suddenly started causing a problem.
I tried deleting the rules and recreating them, but that still causes the problem.
These rules are not required (I originally created them years ago, when I sometimes set them to DENY outbound web access, but since then they have been left enabled but set to ALLOW outbound web access). As they are currently set to ALLOW outbound traffic, they are redundant, so disabling them is an OK solution.
Why this only recently started to cause a problem and why only on some sites is a mystery.
Maybe there's been some difference to the infrastructure on the routes to the different websites that has recently changed, that causes a problem with this router (IPv6 or IPv4 handling?).
Or maybe the router is starting to fail or some internal settings/software has been corrupted somehow. I guess I could try to reset the router to the factory settings and recreate everything...
Anyway, it seems I have a fix for the problem, so thanks for all the help!
If I do find out anymore info that explains it better, I'll make another post.
20-05-2017 5:34 PM
Glad it's sorted
