Slower broadband speeds
PabloBruno
I usually get around 55 Mbps, but today I am only getting around 40 Mpbs. I am aware that this is still above the guaranteed 38 Mbps Plusnet promise me - however, it would be nice to know if this was a temporary glitch or something more permanent.
Kind regards.
38 REPLIES 38
Legend
Fixes: 260
Re: Slower broadband speeds
@PabloBruno You keep asking this, or variations on it, every so often - people attempt to help you, but you seem reluctant to follow the advice/help offered. Assuming you are on FTTC, can you please reply to the below, and maybe some of us could advise?
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
PabloBruno
I think I have always accepted their advice as I am desperate for a long-term, stable connection. Here are all the screenshots you requested.
I have no phone and never use the landline so cannot carry out the other tests.pn7.JPGpn6.JPGpn5.JPGpn4.JPGpn1.JPGpn3.JPGpn2.JPG
Legend
Fixes: 260
Thanks for this.It appears from that information that you are/have been suffering from xDSL drops, which will account for the reduced speeds experienced. I also note your downstream SNR is very low. How far are you from your VDSL cabinet?
PabloBruno
I'm afraid to say that I have no idea where the Crouch End VDSL cabinet 10 is.
Legend
Fixes: 260
Do you know where your nearest cab is? - that is usually the one you are connected to.
PabloBruno
As I say, no idea I'm afraid.
Legend
Fixes: 260
Do you not notice them when out and about - they are big and green?
Aspiring Hero
Fixes: 81
I would look here
HTH
PabloBruno
No. I have lived here 5 years and have not seen one. Hence, that is why I said I did not know where it is.
If it is Lightfoot Road, then that is half a mile away and a ten minute long walk to an area I usually don't go to.
PabloBruno
Should I keep on here to find out my next steps - or with that information, should I speak to Plusnet and get an engineer to investigate?
Legend
Fixes: 260
That distance sounds about right for the data in the BTw report earlier.
My suggestion is:
IIf the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
PabloBruno
I did as requested. The came back (text), saying that, "the line from the network to your home appears to be performing well."
They asked me to text back 'REFRESH', which I did, but I was a then told, "we haven't been able to refresh your connection." So, I followed their instructions of turning my hob off/on and waiting 5 mins.
I just did another speed test and it's back up to 48-51 Mbps.
My concern is that, as has been noted, this keeps happening. Please let me know how I get this investigated further.
Many (continued) thanks.
Legend
Fixes: 260
Bearing in mind that this is more than likely a fault in the Openreach network, it would be interesting to see a Visual Radius graph. At one time, Help Team members would oblige with one of these, plus the results of a line test, but since PN have become merely a 'brand' of the BT Consumer Division, getting such helpful data is a massive struggle - to put it politely.
I suggest you wait until tomorrow, and I'll see if I can catch the eye of a Help Team staffer - but don't hold your breath, they now have to work to GPO Telephones - sorry BT Group - rules.
PabloBruno
I really appreciate you going above and beyond. I will wait patiently for any feedback/advice.
Fwiw, my take-away from my long list of BT faults is that I find it astonishing that two companies (one owned by the other) have such limited lines of comms in the 21st Century... and both being teleCOMS companies.
