Slow adsl2+ upgrade
- Slow adsl2+ upgrade
Slow adsl2+ upgrade
08-02-2012 2:27 PM
Current router stats
Connection Speed 8128 kbps 832 kbps
Line Attenuation 21.0 db 11.5 db
Noise Margin 12.8 db 17.0 db
Re: Slow adsl2+ upgrade
08-02-2012 3:06 PM
I've just looked into this and can see that there's been a delay against the order in question. In these circumstances I'd usually cancel it and place a new one manually. However the original order is set to complete on the 15th so I don't see any point to doing that now.
16-02-2012 11:43 AM
Would seem although i'm now on adsl2+ the router is only syncing at adsl speeds? as well as lossing half my upload.
Is this likely to go up during the 10day training period or is something wrong?
Connection Speed 8128 kbps 445 kbps
Line Attenuation 24.5 db 13.1 db
Noise Margin 20.4 db 31.6 db
16-02-2012 12:12 PM
At first I though you had been transferred to the 21CN network but left on ADSL1 service and not also changed over to ADSL2+ and this was why the sync wasn't changing.
But then I saw your attenuation has gone up by the usual 3dB you get when you swap to ADSL2+
So why, given your noise margin is huge, isn't the sync increasing
I recall somewhere seeing that something else needs to be done to allow the line to sync above 8128 but can't remember if this is correct or whether I'm talking rubbish.
Yup, something is definitely odd somewhere.....
16-02-2012 12:17 PM
You need to make sure Max Premium is removed from your account as you don't need to pay for the faster uploads on 21CN.
16-02-2012 12:55 PM
Hopefully someone will be along soon to pick this up.
16-02-2012 1:01 PM
16-02-2012 1:06 PM
16-02-2012 2:01 PM
Just been investigating this and it looks like the order was placed for up to 8Mbps rather than up to 20. I'll place an order to change that, which will take effect tomorrow. Sorry about that.
Jojo
p.s. I've also made sure the upstream is uncapped
16-02-2012 2:08 PM
16-02-2012 2:46 PM
16-02-2012 2:53 PM
