Slow Speeds ( SOLVED )
- Re: Slow Speeds
23-06-2010 4:38 PM
You are currently connected to the "City Lifeline, Juniper 11" gateway. This gateway is sometimes known as pcl-ag04.
Re: Slow Speeds
23-06-2010 4:42 PM
Re: Slow Speeds
23-06-2010 4:45 PM
Re: Slow Speeds
23-06-2010 4:52 PM
We can only apologise for the inconvenience as on the service status, as you can appreciate these are exceptional circumstances and we do expect things to settle back down shortly.
Jojo
Re: Slow Speeds
23-06-2010 4:53 PM
Re: Slow Speeds
23-06-2010 4:54 PM
Re: Slow Speeds
23-06-2010 4:58 PM
Quote from: Steve Wonder if it would be the same if scotland were playing!!! Thanks for the reply jojo.
We have the Scottish to thank for high usage when Murray is playing at Wimbledon
Re: Slow Speeds
23-06-2010 4:59 PM
I see you're in the process of raising a fault, so as you are waiting for that to be investigated you may like to view this link;
http://community.plus.net/blog/2007/07/02/broadband-speed-faults-how-to-diagnose/
it's packed full of information and should answer many of your questions about speed issues.
Jojo
Re: Slow Speeds
23-06-2010 5:07 PM
Re: Slow Speeds ( SOLVED )
23-06-2010 9:34 PM
24-06-2010 9:21 AM
