Setting up new router
jomerefolly
Hello everyone,
Setting a new router up, when setting the server settings in the router pages I type username@plusdsl.net, for the password would I put the password I use to sign into plusnet on line, I have the password I used originally written down but when I type it in I get wrong password, can anyone help me with this please.
Best regards
Jo Handy (Mrs)
5 REPLIES 5
Fixes: 404
Re: Setting up new router
@jomerefolly
yes , its the password you would use to login here https://www.plus.net/member-centre/login
The link above has a 'forgotten pasword' option, which will send a change password link to the registered email address for your account.
Are you using your own router ? because all Plusnet supplied ones should auto configure
Legend
Fixes: 258
@jomerefolly Welcome to the forums. I assume you type your username, rather than the word 'username'?
jomerefolly
Yes I was using my own router, I had to reset it for a reason which is to long winded to explain why :-), I'm using a BT home hub at the minute but my own router is a TP Link VR600, never had any problems with it until I decided to reset it (bad move), the BT home hub is working but I had set that up a few years ago, I will try plugging the TP Link router back in and click on the link you have kindly sent me thank you.
Best regards
Jo Handy
jomerefolly
Yes I was using my own user name when typing it and not just username
Best regards
Jo Handy
Aspiring Hero
Fixes: 77
@jomerefolly
If the DSL modulation type is VDSL then you'll need to add a VLAN ID 101
HTH
