Saving defaults on the TG582n
- Re: Saving defaults on the TG582n
16-09-2012 11:36 AM
I am running this with firmware 10.2.2.9. I have tried to set the following but some return to the default settings:
Under Home Network
Wireless Power Save . Default is on but I want off
WPS: Default on but I want off
Encyption, Default WPA-PSK and WPA2-PSK but I want WPA2-PSK only.
DHCP scope: ...54 to ...253 as default but I want ...1 to ...100
SSID default is plusnetxxxxxx I want xxxxxx
After a reboot (not reset) these settings revert to default. Am I going to have to do a config backup and restore everytime I reboot the modem?
Regards
Adam.
Under Home Network
Regards
Adam.
Message 1 of 5
(2,964 Views)
4 REPLIES 4
16-09-2012 11:53 AM
Did you click the "Apply" button after making the changes?
David
Message 2 of 5
(651 Views)
16-09-2012 4:05 PM
Yes I did, at all times.
Adam
Adam
Message 3 of 5
(651 Views)
16-09-2012 6:10 PM
Have you tried with 10.2.0.B?
I am having the same problem with being unable to save the wireless settings using 10.2.2.9 and have put it down to 10.2.2.9 being BETA software.
PeteB
PeteB
Message 4 of 5
(651 Views)
19-09-2012 9:10 PM
As far as I can see, neither 10.x versions are production. They both have "demo" watermarked on the interface. However, I can confirm your findings. The user defaults are saved on V 10.2.0 without problem and you gain the wireles auto channel selection.
A.
A.
Message 5 of 5
(651 Views)
