Rubbish Router
- Re: Rubbish Router
Re: Rubbish Router
24-09-2014 8:48 AM
so are you saying that as long as the 582n looked better but was actually still rubbish then that would be ok? as that is what it looks like you are saying.
the sky SR101/102/201 etc is dross, it's locked down and suffers from poor wifi range.
the bt home hub is over priced in my opinion.
i've seen some expensive routers that look god awful too... asus springs to mind.
Re: Rubbish Router
24-09-2014 9:45 AM
Please don't think I was trying to suggest that just because something looks good that it performs well
What I am suggesting from what I read on this forum is that not only does the 582n look naff, it's wireless performance is also naff, maybe others think it's a cracking bit of kit & I have the wrong end of the stick.
This is fine because it does not cost anything when signing up but compared to Sky & BT it looks naff & people will make comparisons even though technically the other offerings maybe worse.
This is why I think Plusnet should offer something better but we would have to pay for it at signup.
Just saying
Re: Rubbish Router
24-09-2014 9:53 AM
If a router is factored into my monthly charge I want a refund
Re: Rubbish Router
24-09-2014 12:28 PM
Quote from: jelv AIUI, if you connect a single 11g device the 582 drops to 11g speeds for ALL devices (including devices that had previously been running at higher speeds).
This behaviour is not required, I doubt it's what the 582n does but I'll check later. Throughput speeds do decrease because of the additional overheads of the protection mechanisms, but there's no need to drop everything down to the lowest common speed. Why would there be - it doesn't matter if an 11g device can't understand the whole contents of something transmitted from an 11n router to another 11n device.
Quote from: jelv Question 1: If the 11g device is disconnected do the speeds return what they were are do you have to do something to the router (e.g. stop/start the wifi or reboot)?
Depends on the router, but yes the speeds could return once the 11g device is disconnected.
Quote from: jelv Question 2: Could 11g devices of neighbours make the speed drop back (e.g. just getting the names of available networks in the area)?
The protection mechanisms protect you from them as much as they protect them from you, so it depends on devices on the same channel, regardless of what network they are on.
Re: Rubbish Router
24-09-2014 3:26 PM
Re: Rubbish Router
24-09-2014 3:29 PM
buying a different router isn't going to change that.
Re: Rubbish Router
29-09-2014 8:08 AM
Quote from: chenks76 the bt home hub is over priced in my opinion.
The BT Home Hub is free when you sign up to a 12 month BT Infinity contract. I've signed a 18 month contract with Plusnet yet they still can't even provide a decent (IMHO) router!
Re: Rubbish Router
29-09-2014 8:12 AM
try buying one without the stipulation of a contract and see how much they charge you.
as has been said, you are free to use your own router if you wish, you are not tied to using the supplied router.
Re: Rubbish Router
29-09-2014 8:15 AM
Re: Rubbish Router
29-09-2014 8:31 AM
Re: Rubbish Router
29-09-2014 12:23 PM
Re: Rubbish Router
30-09-2014 3:23 PM
Quote from: AndyH Plusnet is a low cost broadband supplier?
Okay I'll use TalkTalk as my example.
TalkTalk unlimited 38mb down is £13.50/month.
Plusnet unlimited 38mb own is £15.00/month
TalkTalk are able to supply a dual band router whilst Plusner aren't.
Re: Rubbish Router
30-09-2014 3:44 PM
talk talk £1.50pm cheaper - but god awful ghastly customer support.
i'd rather pay the extra £1.50pm and have a technicolor router.
Re: Rubbish Router
01-10-2014 5:23 AM
Re: Rubbish Router
01-10-2014 5:51 AM
Quote from: hillyfields123
TT use a cheaper package with a 2mbit upload speed not 20mbit as PN from what I can gather, line rental saver also looks to be more expensive too..
