Router resets evrytime I try to use it
- Router resets evrytime I try to use it
- « Previous
- 1
- 2
- Next »
Re: Router resets evrytime I try to use it
10-11-2011 9:52 AM
I'd swap to a different router. It looks like others are experiencing the same problem. For example see thread http://community.plus.net/forum/index.php/topic,99855.0.html
Message 16 of 19
(288 Views)
03-02-2012 11:07 PM
Ah ha ... I had this exact problem over Christmas ... then not again until two days ago. Finally noted the common cause:
1: All wireless devices (bar one) work ... including various apple devices (which thomson router had issues with)
2: My lenovo w520 works on a wired connection
3: My lenovo w520 works on a wireless connection , while connected to the mains
4: My lenovo w520 on a wireless connection , running on battery, causes the thomson router to reboot within 30 seconds of starting to use it.
This is clearly a router bug. If there was a 'legal way' a laptop could cause any router to reboot , image what would happen if you
took one into the office.
Product Name: TG585 v8
Serial Number: xxxxxxxx <elided>
Software Release: 8.2.7.8
Message 17 of 19
(288 Views)
03-02-2012 11:18 PM
I have a lenovo t510 which would reboot my 3com router constantly. Turned out to be the ip helper service that was running In windows 7. Disabling I fixed it completely.
Message 18 of 19
(288 Views)
04-02-2012 2:39 AM
So A T510 ... I betting it's the "Intel Centrino Advanced-N 6200 " version (or 6300)
* Integrated Mobile Broadband (Gobi 2000 3G with GPS) on selected models
* Intel® Centrino® Wireless-N 1000 on selected models
* ThinkPad 11b/g/n Wireless LAN Mini-PCI Express Adapter II on selected models
* Intel Centrino Advanced-N 6200 on selected models
* Intel Centrino Ultimate-N 6300 on selected models
* Intel Centrino Advanced-N + WiMAX 6250 on selected models
* Bluetooth with Enhanced Data Rate (BDC-2.1)
Message 19 of 19
(288 Views)
- « Previous
- 1
- 2
- Next »
