Re: Persistent Dropped Connections.
- Re: Persistent Dropped Connections.
21-05-2015 4:22 PM
24-05-2015 4:16 PM
Thanks for all the help
I can recommend this router for long lines
25-05-2015 2:35 PM
26-05-2015 5:23 PM
28-05-2015 12:28 PM
Engineer has just left , found high resistance in the connection , remade the connections in the box , reset my connection and asked me to ask you to have my BRAS reset to 3.5mb by BT wholesale,
will continue to monitor but fingers crossed its sorted ,
thanks for the help
28-05-2015 12:42 PM
Your sync rate has increased too, but I cannot see your bRAS profile. I've changed our side to what I'd expect it to be. Please disconnect, reconnect and let me know if it's not sorted.
28-05-2015 12:55 PM
here is a screen grab from bt performance test
many thanks
28-05-2015 1:34 PM
28-05-2015 1:41 PM
28-05-2015 2:03 PM
29-05-2015 4:40 AM
thanks ,
just to add i have checked my router stats and i had 2 disconnects during the night 1 at 21.12pm snr dropped to 0 and straight back up and another at 02.11am snr dropped to 0 and straight back up and another at 08.00am snr dropped to 0 and straight back up but an increase in connection
29-05-2015 10:18 AM
The continued disconnects sugget that there are still issues with your line. Keep doing the quiet line tests, especially when you notice a disconnect and keep RouterStats running. Multiple faults on a line requiring several BTOR attempts to fix are unfortunately not uncommon. The BT profile will not change whilst the line remains unstable.
You have though made good progress.
Kevin
30-05-2015 12:52 PM
i have just done a broadband fault report on the user page of my plusnet, will see what happens next
30-05-2015 4:33 PM
30-05-2015 5:07 PM
The report was made around 12.55
