Re: Lower Sync / Broadband speed , stuck profile?
- Re: Lower Sync / Broadband speed , stuck profile?
02-07-2009 1:03 PM
My profile went down to 1500 about 4 days ago but has not gone back up again.
Its usually around 4000-5000.
I have had no disconnections since and have not rebooted by router.
Please could you increase my profile as I think it is stuck (it should usually go back up after a few days)
Cheers Keith
02-07-2009 1:08 PM
I've just increased your profile to 3500Kbps.
02-07-2009 1:34 PM
03-07-2009 7:09 AM
It hasn't made any difference
I just done the BT speedtest and the profile is still 1500. I have also tried rebooting the router
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 4480 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 1500 kbps
Actual IP throughput achieved during the test was - 1385 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
Re: Re: Lower Sync / Broadband speed , stuck profile?
03-07-2009 7:14 AM
Split out from goomy's thread
03-07-2009 7:20 AM
03-07-2009 7:53 AM
03-07-2009 1:07 PM
Not sure what to do Jameseh
I also tried swapping the router which didn't work either
03-07-2009 1:50 PM
You might have to wait a little bit longer for the BT Speedtester to update, otherwise we'll raise a fault with BT to fix a stuck profile.
03-07-2009 2:23 PM
03-07-2009 2:47 PM
Your DSL connection rate: 7616 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 6500 kbps
Actual IP throughput achieved during the test was - 1579 kbps
Tony
03-07-2009 3:08 PM
I've just changed it to 6500Kbps.
03-07-2009 3:24 PM
Thanks. I will close the ticket.
Tony
