Re: DNS weirdness
- Re: DNS weirdness
Re: DNS weirdness
12-07-2009 6:36 PM
Has the site been fully propagated to the network yet? A question for theplanet.com
doing an nslookup on the ip address does not resolve to the site name - just the static address bb.b4.344a.static.theplanet.com
Have you checked with the Webhost on your problems?
Maurice
Re: DNS weirdness
12-07-2009 6:38 PM
That is a bit messy as Speedtouch, as usual try to stop you altering things
Quote from: Nocturne Speedtouch 546 FW 6.1.4.7
Many thanks
[Moderator's note by Jim (Oldjim): Full quote of preceding post removed, as per Forum Rules ]
You need to telnet into the router
See the attached picture
Once in type the following - after each line hit enter
dns server route add dns=208.67.222.222 metric=1 intf=Internet
dns server route add dns=208.67.220.220 metric=1 intf=Internet
This adds those two DNS servers and gives them a higher priority than the automatic ones
Re: DNS weirdness
12-07-2009 6:41 PM
Re: DNS weirdness
12-07-2009 6:44 PM
I have no idea who planet.com are to check anything with them.
The host company for the ecommerce site servers say they are working fien and have no problems - and they can see it also...as can I from my locallibrary.
So I |DO think it is something to do with Plusnet - and a greta shame they do not rtspond very quickly/aptly to my support messages.
Re: DNS weirdness
12-07-2009 6:48 PM
Re: DNS weirdness
12-07-2009 7:10 PM
www.dimplesdaisysanddandelions.co.uk
www.dimplesdaisysanddandelions.co.uk/index.php
www.dimplesdaisysanddandelions.co.uk/admin?
...or maybe just part company with Plus Net.....
Re: DNS weirdness
12-07-2009 7:15 PM
Many Many thanks to all contributors who ahve helped in this.
Re: DNS weirdness
12-07-2009 7:44 PM
Open DNS site confirms I am using OpenDNS.
I couldn't open some of their pages before and still can't but perhaps some progress.
Plusnet's Portal ie Log In page still times out.
I'm sure whatever the problem is it will be sorted in the near future.
Edit Image:
Re: DNS weirdness
12-07-2009 7:51 PM
Can you do a tracert to plus.net
C:\Users\James>tracert plus.net
Tracing route to plus.net [212.159.9.2]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms 192.168.0.1
2 40 ms 39 ms 39 ms lo0-plusnet.pcl-ag03.plus.net [195.166.128.109]
3 40 ms 39 ms 39 ms gi1-6-703.pcl-gw01.plus.net [84.92.0.181]
4 39 ms 38 ms 39 ms te2-2.pte-gw1.plus.net [212.159.0.186]
5 40 ms 39 ms 38 ms te2-4.pte-gw2.plus.net [212.159.1.102]
6 43 ms 44 ms 44 ms 92.core.plus.net [212.159.1.92]
7 43 ms 44 ms 46 ms fhw-lb04.plus.net [212.159.1.146]
8 44 ms 89 ms 61 ms portal.plus.net [212.159.9.2]
Trace complete.
Re: DNS weirdness
12-07-2009 7:59 PM
Tracert shows
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Graham Pritchard>tracert www.dimplesdaisysandandelions.co.uk
Unable to resolve target system name www.dimplesdaisysandandelions.co.uk.
Re: DNS weirdness
12-07-2009 7:59 PM
Edit: Don't waste too much time on this Jim.
Assuming it gets sorted in a few days I'll survive
Regards
Re: DNS weirdness
12-07-2009 8:03 PM
C:\Users\Graham Pritchard>tracert 208.67.222.222.
Tracing route to 208.67.222.222. [208.67.222.222]
1 2 ms 1 ms 1 ms 192.168.2.1
2 36 ms 36 ms 36 ms lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]
3 37 ms 35 ms 35 ms gi2-2-204.ptn-gw02.plus.net [84.92.3.93]
4 35 ms 36 ms 35 ms vl32.ptn-gw01.plus.net [195.166.129.9]
5 35 ms 36 ms 41 ms te2-2.thn-gw1.plus.net [212.159.1.54]
6 37 ms 36 ms 36 ms gi8-7.mpd01.lon01.atlas.cogentco.com [149.6.2.33
7 43 ms 37 ms 37 ms opendns.demarc.cogentco.com [149.6.146.158]
8 40 ms 36 ms 36 ms resolver1.opendns.com [208.67.222.222]
Trace complete.
Re: DNS weirdness
12-07-2009 8:31 PM
It's not just you! http://www.dimplesdaisysandandelions.co.uk looks down from here.
Re: DNS weirdness
12-07-2009 8:36 PM
nslookup works both on the sitename and from the resulting IP address
nslookup www.dimplesdaisysanddandelions.co.uk results in an IP address of 74.52.180.187
Maurice
Re: DNS weirdness
12-07-2009 9:02 PM
If so then surely doesn't that indicate the problem lies squarely with them??, and if so they should own up and confirm what they are doing to resolve the issue.
