Re: DNS weirdness
- Re: DNS weirdness
Re: DNS weirdness
12-07-2009 9:04 PM
Re: DNS weirdness
13-07-2009 9:01 AM
I also queried this with my ISP providr - here is their view....
The following comment was added to the Question
Dear Mr Pritchard,
Thanks for getting back in touch.
I can confirm from testing using all our dns servers none resolve the domain www.dimplesdaisysanddandelions.co.uk however using an alternative dns server this does resolve to the IP 74.52.180.187.
As such it would appear the DNS servers simply do not have the correct information, normally this means the host hasn't distributed this correct, requesting a refresh of this should issue our DNS servers with the correct information.
However in the meantime I am going to escalate this for the attention of our networks team to review and see if there is anything they can force through however please note this may take several days.
In the meantime I would recommend you query this with the host.
[internal]
Unable to ping or view www.dimplesdaisysanddandelions.co.uk using our dns, external dns server are successful and also the internal dns servers also work fine.
Would recommend adding this to our dns servers if possible.
Kind regards,
link:csa removed
Read or respond to your Question -
http://portal.plus.net/my.html?action=questions
IMPORTANT: Do not reply to this email, our Support Team can only deal with inquiries through the Help Assistant
Regards,
Customer Support
adie:red CSA name removed as per link rules mode:end
Re: DNS weirdness
13-07-2009 1:56 PM
Re: DNS weirdness
13-07-2009 2:24 PM
When I am trying to resolve this in a forum/ISP support/Host etc and typing quickly I think everyone knows the www address is as originally shown.
Re: DNS weirdness
13-07-2009 2:31 PM
Also given that one of the addresses you originally quoted was incorrect, your comment is a bit optimistic
![Undecided Undecided](/html/@B2520ED9758574DA4DA10314C4B1AB94/images/emoticons/undecided.gif)
Maurice
Re: DNS weirdness
13-07-2009 3:11 PM
There are a number of sites I still cannot access including the Plusnet Portal.
Re: DNS weirdness
13-07-2009 3:12 PM
I appreciate that there were issues reported yesterday, however I've been monitoring these forums today and I haven't seen any generic issues being reported apart from a couple of isolated examples.
Re: DNS weirdness
13-07-2009 3:23 PM
I posted some info yesterday, which is now on the previous page, including a tracert to Plusnet.
I have also installed the OpenDNS details into my router as the image I posted.
I can bring up www.plus.net but the 'link' to the Log In page eg 'https://portal.plus.net/index_portal.html?home=login' times out and has done since yesterday, although prior to that I haven't tried to log in for many weeks.
Can you offer any advice on how I might proceed.
Re: DNS weirdness
13-07-2009 3:24 PM
Do you see similar problems on other https:// sites?
I'm just wondering if it's only secure ones which are being problematic, in which case its more likely to be your browsers security settings than our DNS servers (especially as you're not using them anymore!).
Re: DNS weirdness
13-07-2009 3:25 PM
« on 12/07/2009, 15:42 »
I joined this comminity specifically because I cannot access an ecommerce site that I am develping for a client.
www.dimplesdaisysanddandelions.co.uk/index/php
www.dimplesdaisysanddandelions.co.uk/admin
Dis a tracert on 208.67.222.222 and got this....
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Graham Pritchard>tracert www.dimplesdaisysandandelions.co.uk
Unable to resolve target system name www.dimplesdaisysandandelions.co.uk.
Quote « Reply #39 on 12/07/2009, 19:59 »
Back agaian....afraid I am still stuck with the proble.
Tracert shows
Re: DNS weirdness
13-07-2009 3:37 PM
Quote from: Jameseh Hiya,
There are a few situations where I can access the site but other 'pages' on those sites time out.
At least some of them I'm sure are not 'secure' pages although this example appears to be 'https://www.opendns.com/start/' on OpenDNS site.
I have updated from Firefox xxx to Firefox 3.5 so I will check and see if that could be the problem.
Thank you.
Edit: It does appear to be https pages that are causing the problem.
Further edit: Excuse my blushes but I seem to have created a rule in the Firewall to block certain sites and succeeded in blocking all https ie port 443.
I saw the posts relating to DNS issues and put two and two together and came up with 5
![Embarrassed Embarrassed](/html/@6CEFBAD878A40FF337662307A879A7FD/images/emoticons/embarrassed.gif)
Re: DNS weirdness
13-07-2009 3:53 PM
Re: DNS weirdness
13-07-2009 3:59 PM
I've edited my previous post
your comments put me in the right direction
Re: DNS weirdness
13-07-2009 4:01 PM
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
Maurice
Re: DNS weirdness
14-07-2009 3:11 PM
Quote from: gprit So...mixed results about accessing the site.....I presume everyone is going through Plus.net to try and access it?
If so then surely doesn't that indicate the problem lies squarely with them??, and if so they should own up and confirm what they are doing to resolve the issue.
Successive lookups to dimplesdaisysanddandelions.co.uk using our DNS caches are failing occasionally (but not always):
bpullen@pvs-csctools:~$ host dimplesdaisysanddandelions.co.uk 212.159.13.49
Using domain server:
Address: 212.159.13.49#53
Aliases:
Host dimplesdaisysanddandelions.co.uk not found: 2(SERVFAIL)
Each time I tried using OpenDNS is worked:
bpullen@pvs-csctools:~$ host dimplesdaisysanddandelions.co.uk 208.67.222.222
Address: 208.67.222.222#53
Aliases:
dimplesdaisysanddandelions.co.uk has address 74.52.180.187
What is strange is that you still seem to have 1 and 1 name server records associated with the domain. A whois shows this:
[quote author="whois"]bobpullen@cshell01:~$ whois dimplesdaisysanddandelions.co.uk
Domain name:
Registrant:
DimplesDaisysandDandelions
Registrant type:
UK Sole Trader
Registrant's address:
2 Gelliwastad Grove
Pontypridd
MGM
CF37 2BS
United Kingdom
Registrar:
Heart Internet Ltd t/a Heart Internet [Tag = HEARTINTERNET]
URL: http://www.heartinternet.co.uk
Relevant dates:
Registered on: 13-Mar-2009
Renewal date: 13-Mar-2011
Last updated: 14-Apr-2009
Registration status:
Registered until renewal date.
Name servers:
ns307.websitewelcome.com
ns308.websitewelcome.com
WHOIS lookup made at 14:48:40 14-Jul-2009
Yet a DIG against the domain returns this:
[quote author="DIG"]bpullen@pvs-csctools:~$ dig @ns307.websitewelcome.com dimplesdaisysanddandelions.co.uk
; <<>> DiG 9.2.4 <<>> @ns307.websitewelcome.com dimplesdaisysanddandelions.co.uk
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 50383
;; flags: qr aa rd; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 0
;; QUESTION SECTION:
;dimplesdaisysanddandelions.co.uk. IN A
;; ANSWER SECTION:
dimplesdaisysanddandelions.co.uk. 14400 IN A 74.52.180.187
;; AUTHORITY SECTION:
dimplesdaisysanddandelions.co.uk. 86400 IN NS ns60.1and1.co.uk.
dimplesdaisysanddandelions.co.uk. 86400 IN NS ns59.1and1.co.uk.
;; Query time: 113 msec
;; SERVER: 74.52.238.210#53(ns307.websitewelcome.com)
;; WHEN: Tue Jul 14 14:54:58 2009
;; MSG SIZE rcvd: 110
AIUI your domain should no longer be affiliated with 1and1 so the first thing I'd do if you haven't already is contact your current host to query this. Let us know what they say and we'll look into things further if needs be.
