Problems with IPlayer & Unlimited & Value
scootie
Re: Problems with IPlayer & Unlimited & Value
Cry any chance of switching my account back to how it was till after the weekend dave
scootie
sry to bump this james but is it possable to make the above happen b4 the end of day  Smiley
Tsonga
Hi there again!
I thought I would download the Franz Ferdinand highlights from Glastonbury (the ones I failed to stream the other night) before they disappear from IPlayer. Apparently I need 49 hours to download a 60 minute programme at 24kb/s! Just did a My Broadband Speed test and the result is 4286 kbps (536kB/s). It is Sunday night, 9pm, so I don't expect this is regarded as peak time, is it? Wireshark says I am on 0x60 (still not sure what it means but I thought you might need all the info)... So, is this a Plusnet issue or a BBC IPlayer one? Or are Franz Ferdinand really really avoiding me?
scootie
downloads of iplayer are classed as 0x60 but the speed you gettin still looks very low
Mav
Fixes: 516
Currently FNWJR HD shows 26:40hours lef for a 60 minute prog. OK so I have another DL using 41KB/s but 26 hours?
Forum Moderator and Customer
Tsonga
It's picked up a bit, downloading 1 item at 32Kb/s.  Huh
jelv
Fixes: 10
Top Gear looks like it's going to complete in around 25 minutes for me - but then I'm on PAYG (equivalent of Pro) and the IP Stream Connect trial.
The only gateway looking even slightly busy at the moment is PCL-AG01 so if you are on that one it may be worth reconnecting to try another.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Tsonga
Not fair!  Wink
Well I am on ptn-ag1 so not the one which is slightly busy: 4 hours 33 left to go so big improvement there, but still, I started this download around 8.30pm and it is now 9.43!
Tsonga
I assume it is too late to go back to my previous package (PlusNet Broadband Your Way Option 3) now is it? I switched to Unlimited on 23 June.
Tsonga
This morning it is downloading at 3.66Mb/s. If anyone can explain this to me I would be grateful.  Smiley
PS: Had to reconnect first thing in the morning; is there a link?
Fixes: 1,485
There aren't any restrictions on downloads until 12 noon - see http://www.plus.net/support/broadband/quality_broadband/speed.shtml
James
Morning,
If you refer to this link:
http://www.plus.net/support/broadband/quality_broadband/speed.shtml#valuespeeds
iPlayer "downloads" are treated as download servers whereas the actual streaming should just be gold traffic.  So, if you're actually downloading from iPlayer, the speeds will be reduced during peak times of the day.
Tsonga
Ah thanks, my mistake, I was convinced weekends were considered off-peak (but maybe I am confusing with something else, BT phone calls perhaps, or train tickets...)!
Would you not say that 24/32 Kb/s is still on the slow side, though? Or can this just be explained by contention, congestion, whatever it is called? The reason I ask is that it is not the first time it happens.
Right, well I've got my download now!  Smiley
Cheers!
James
That's going to depend on whether you mean kibobytes or kilobits Smiley
If we're talking 32 kilobytes during peak times on Value, then that's pretty much how the service is designed to work.
Fixes: 1,485
Quote from: BlueRhizome
why are we talking about Value?
