Problem with connecting to webpages
- Re: Problem with connecting to webpages
- « Previous
- 1
- 2
- Next »
24-07-2009 3:11 PM
OK - now for the acid test - let's see if it is fixed
Message 16 of 22
(419 Views)
24-07-2009 3:14 PM
So do I just wait and see if I have problems with not connecting? as Its been ok so far today but then it is random when it happens.
Message 17 of 22
(419 Views)
24-07-2009 3:15 PM
that is all you can do
Message 18 of 22
(419 Views)
24-07-2009 3:16 PM
Thanks for all your help.
So if it still happens any suggestions what I do?
Message 19 of 22
(419 Views)
24-07-2009 3:23 PM
Let's wait and see first before doing any more playing as the next step could well be accessing the router using the command line interface which isn't a good idea unless we really have to.
Message 20 of 22
(419 Views)
24-07-2009 3:40 PM
Well hopefully that won't be necessary and it is now fixed. I will keep my fingers crossed.
Thanks again for your help and support.
jim:quote
jim:quote
Message 21 of 22
(419 Views)
24-07-2009 3:41 PM
Quote from: Paul03 It's also worth noting that unticking the IPv6 box in the networking properties often helps with Vista (particularly if you're using your router as a DNS proxy).
Most routers can't handle IPv6 requests and PN don't have IPv6 DNS servers so there's no point having it enabled in most cases. (IIRC Vista will try an IPv6 lookup before it tries a normal IPv4 lookup if IPv6 is enabled.)
Thanks for your suggestion, I've unticked the box and followed oldjim's instructions so hopefully the problem is now resolved.
Message 22 of 22
(419 Views)
- « Previous
- 1
- 2
- Next »
