Poor web connectivity this morning
FIXED- Subscribe to RSS Feed
- Re: Poor web connectivity this morning
30-07-2017 10:14 AM
Fixed! Go to the fix.
30-07-2017 10:18 AM
@carlcaulkett - This appears to be a recurring theme this morning. If you can change your DNS to 8.8.8.8 and 8.8.4.4. (Google's) this this should resolve your issue. You can do this in your router so it will change for every device on your network assuming you're using DHCP.
30-07-2017 10:27 AM
Made that change. Instant improvement. Thanks very much!
30-07-2017 10:49 AM
how do u change the dns settings in the plusnet hub one?
30-07-2017 10:54 AM
@horsey - As I understand it you can't! But if you're running Windows this may help as a temporary measure.
Control Panel / Network and Internet
Network and Sharing Centre
On the left select Change Adapter Settings
Select your Network Interface and right click for the context menu and select Properties (at the bottom).
Look for the entry in the list that says “Internet Protocol v4 (TCP/IPv4) and double click it.
On the General tab select the option to “Use the following DND server addresses” and enter 8.8.8.8 and 8.8.4.4 and click OK then OK again.
That should give you a temporary fix until the issue is resolved. But remember to undo once a fix is in place.
30-07-2017 10:56 AM - edited 30-07-2017 10:58 AM
I am having serious issues too.
However, it appears that in my Hub One, DNS settings cannot be changed at source.
Won't this method mean that all the connected devices need to be altered as well?
30-07-2017 11:00 AM
Yes, regrettably this is the case. I don't even know for sure if there is a Plusnet DNS issue, but you could try a restart of the router, before making any changes, nothing ventured nothing gained.
30-07-2017 11:03 AM
I had this problem earlier. A total disconnect - switch off router - wait five minutes - restart router has seemed to fix it.
(TG582N router)
30-07-2017 11:48 AM
We’re investigating a potential problem where some customers may be having problems accessing websites or online services.
We'll provide updates when available Here
30-07-2017 12:01 PM
to be fair this didnt make a diffrence
30-07-2017 6:34 PM
We have had problems too, like gmail, hotmail and many sites as well, but some sites were okay. Everything seems fine now just was problematic this morning and this afternoon
