Plusnet and BT core network issues - high to total packet loss
97ReBrkkFRCf
Since yesterday I have been experiencing issues with my broadband connection.
Today I have been running a trace on the routes though to bbc.co.uk and have observed issues across the core network.
I called to report an issue, however the test identified a poor connection at the cabinet which may reduce the speed or cause dropping it is in addition to the MAJOR issues the traces above point to. In those I am clearly connected and traffic is either being partially dropped or failing to route in the Plus Net and BT networks.
2 REPLIES 2
Aspiring Hero
Fixes: 76
Re: Plusnet and BT core network issues - high to total packet loss
@97ReBrkkFRCf welcome to the forums.
Are you testing using a wired or wireless connection? It really should be wired.
Looking at your MTR output you have 37.9% lost packets to you default gateway your Hub 192.168.1.254
bobpullen
Fixes: 316
Yep, there's huge loss between the machine you're running MTR on and your router. That has nothing to do with the network beyond.
